I’m running maps for a relatively large system without any symmetric feature. So far, maps has generated more than 1400 structures and vasp calculations (pollmach runstruct_vasp) were finished for several hundreds of generated structures. But, maps.log still shows "Not enough known energies to fit CE" and refuse to generate ouput files for the cluster expansion.
I understand my system might be too huge, but the energies for many composition points were alread collected. Should I continue waiting for more vasp results to generate output files? Since this process has lasted for more than one week, I’m worry about mistakes or bugs in my calculations.
I attached my lat.in here. I will appreciate if you could give an advice.
and you have 98 nearest neighrbor pair clusters. This would take forever to fit.
I looked at your cell and it seems to have a lot of periodicity tat is broken by just a few substitutional defects. Perhaps you want to model this as a multiple-sublattice system instead?
Thank you so much for the kind reply. The problem is indeed the large system and absence of periodicity. I will simplify the initial structure to proceed the calculation based on your advice. Thank you.
