problem with temperature control
Hi all,
I met a problem of temperature control when constructing the liquid/vapor interface. I used the “fix spring/self” command to fix the atoms of upper and lower walls, and used “fix langevin” command to control the two walls at different temperatures (1.1 and 0.75) after equilibration. Then I found that the temperature of liquid between two walls is much higher than both walls, which is not reasonable. Can someone tell me what the problem is? Thank you in advance.
The following is my input file:
2-d LJ flow simulation
boundary p p s
atom_style atomic
neighbor 1.0 bin
neigh_modify delay 5
create geometry
lattice fcc 0.05
region box block 0 50 -13 13 0 140 units box
create_box 3 box
mass 1 1.0
mass 2 4.0
mass 3 4.0
LJ potentials
pair_style lj/cut 3.0
pair_coeff * * 1.0 1.0 3.0
define groups
region 1 block 0.5 49.5 -12.5 12.5 1.3 138 units box
create_atoms 1 region 1 units box
lattice fcc 2.6
region 2 block 0.5 49.5 -12.5 12.5 0 1.3 units box
create_atoms 2 region 2 units box
group lower region 2
region 3 block 0.5 49.5 -12.5 12.5 138 140 units box
create_atoms 3 region 3 units box
group upper region 3
group boundary union upper lower
group flow subtract all boundary
initial velocities
velocity flow create 1.1 1081275 units box
fix 1 all nve
fix 2 flow langevin 1.1 1.1 0.02 699483
fix 8 lower langevin 1.1 1.1 0.02 699483
fix 9 upper langevin 1.1 1.1 0.02 699483
fix 105 lower spring/self 3200
fix 106 upper spring/self 3200
compute Tupper upper temp/com
compute Tlower lower temp/com
compute Tflow flow temp/com
thermo_style custom step temp epair emol etotal press vol c_Tupper c_Tlower c_Tflow
Run
timestep 0.001
thermo 100
dump 1 all atom 5000 dump.flow
dump_modify 1 scale no
run 20000
unfix 2
unfix 8
unfix 9
fix 8 lower langevin 0.75 0.75 0.02 699483
run 100000
Best regards
Wenjing Zhou
Don't know - don't see anything obviously wrong with
your script. I would simplify the model, starting
with the basics, and add features one at a time.
Thanks, Steve. Another question: I know that using the combination of “fix temp/rescale” and “compute temp/region” commands I can thermostat atoms in a geometric region, but I want the temperature to be calculated after subtracting the spatially-averaged velocity in the region during the thermostat. What kind of command should I use? or I have to write my own “compute” and “fix”? Thank you.
Best regards
Wenjing Zhou
In LAMMPS lingo, both the COM velocity and the
region definition are "biases" on the temperature.
There is a compute temp/com and temp/region that
does this. You're asking for a temperature that
subtracts both biases. Can't think of a way to
do this at the moment. Maybe there would be a clever
way to apply multiple biases if the computes were
restructured a bit. But for now I think you'd need
to write your own compute which applied both biases.
