please always reply to the mailing list and not only individual people. thanks.
Dear Alex, thanks a lot.
I fetched and merged your pull request. I still seem to have a problem, here are my relevant keywords in the input file,
pair_style hybrid lj/cut 13.0 sw tersoff
pair_modify pair sw compute/tally no
pair_modify pair tersoff compute/tally no
pair_modify pair lj/cut compute/tally yes
compute f56 l5 force/tally l6
dump test l5 custom 10 F_56.dat id c_f56[1]
The interactions between groups l5 and l6 are defined to be lj/cut explicitly using pair_coeff command. The error I get is the same again, “Compute force/tally used with incompatible pair style”. Pair_modify commands seem to go through fine.
Am I missing something? Thanks a lot in advance.
Cheers,
Vikram
here are my relevant keywords in the input file,*pair_style hybrid lj/cut 13.0 sw tersoff *
*pair_modify pair sw compute/tally no*
*pair_modify pair tersoff compute/tally no*
*pair_modify pair lj/cut compute/tally yes*
*compute f56 l5 force/tally l6 *
*dump test l5 custom 10 F_56.dat id c_f56[1]*
commands seem to go through fine.Am I missing something? Thanks a lot in advance.
no. i think, the error in the compute styles needs to be converted into a
warning. i've updated the pull request accordingly.
Thanks a lot, works now. I made some trivial tests and compared with compute group/group command and I get the same results.
Thanks again,
Vikram
