problems about ave/correlate and outputs
By citing the example, the following codes can be used to compute the viscosity from Green-Kubo methods (abdahbhg.png):
reset_timestep 0
variable pxy equal pxy
variable pxz equal pxz
variable pyz equal pyz
fix SS all ave/correlate $s $p d & v_pxy v_pxz v_pyz type auto file S0St.dat ave running variable scale equal {convert}/(${kB}$T)$V* s*{dt}
variable v11 equal trap(f_SS[3]){scale} variable v22 equal trap(f_SS[4])*{scale}
variable v33 equal trap(f_SS[5])
${scale}
thermo_style custom step temp press v_pxy v_pxz v_pyz v_v11 v_v22 v_v33
run 600000
variable v equal (v_v11+v_v22+v_v33)/3.0
And right now, I just want to generate the result of hdbibhga.png, no integral is needed, how should I revised the codes? I changes the codes as below, but error occurred. How should I change the codes? I read the lammps mannual several times, however, I still can not get the point.
variable
reset_timestep 0
fix SS all ave/correlate $s $p d & v_pxy v_pxz v_pyz type auto file S0St.dat ave running variable scale equal {convert}/(${kB}$T)V variable v11 equal f_SS[3]*{scale}
variable v22 equal f_SS[4]*{scale} variable v33 equal f_SS[5]*{scale}
Your help will be greatly appreciated!!!
viscosity from Green-Kubo methods ():
reset_timestep 0
fix SS all ave/correlate $s $p d &              v\_pxy v\_pxz v\_pyz type auto file S0St\.dat ave running variable scale equal {convert}/(${kB}*$T)*$V* s\*{dt}
variable v11 equal trap(f_SS[3])*\{scale\} variable v22 equal trap\(f\_SS\[4\]\)\*{scale}
variable v33 equal trap(f_SS[5])*${scale}
run 600000
And right now, I just want to generate the result of , no integral is
​what error?​
variable
​the term your describe is not a point but a list, as it is a function of
time t, which is then discretized ​with using discrete time steps.
​axel.​
