Dear Sir/Madam,
Excuse me,I am in trouble with “fix evaporate command” when simulating a fluid flow.The whole process of flow is under nve ensemble.The command is as follows:
"fix deleteatom argon evaporate 10 1 atomsink 8899"
I hope to delete 1 particle every 10fs at the export without affecting the temperature of fluid in this region . Unfortunately, the temperature jump to a high level .How could I achieve this step -only "delete 1 particle every 10fs " without this unfavorable influence under natural condions? Other effective command or How to modify the "fix_evaporate.cpp“?
Thank you for your reply!
Youwei Gu
From Tsinghua University
