I run a simple system with two groups, top and bottom. The displacement of all atoms is limited by the “fix spring/self” command:
fix 1 all spring/self 6.7867
And I want to compute the mean square displacement of the two groups with the “compute msd” command. Everything goes as expected when I run the input file, and a restart file is saved. But when I restart from the restart file, only the group specified by “compute msd” is still limited, for example, if I compute the MSD of group top:
compute msd top msd
when I restart, atoms in group top are limited near the initial position, but atoms in group bottom move everywhere. Why does the “compute msd” command change the effect of “fix spring/self” command?
The input code:
units real
atom_style full
neighbor 0.3 bin
neigh_modify delay 5
lattice fcc 3.61
region box block 0 10 0 10 -10 10
region top block 0 10 0 10 4 5
region bottom block 0 10 0 10 -5 -4
create_box 2 box
mass 1 18
mass 2 18
pair_style lj/cut 10
pair_coeff 1 1 1.376513974 2.8
pair_coeff 2 2 1.376513974 2.8
pair_coeff 1 2 0 2.8
create_atoms 1 region top
create_atoms 2 region bottom
group top region top
group bottom region bottom
velocity all create 100 87287 dist gaussian
compute msd top msd
fix 2 all nve
timestep 0.2
thermo 1000
thermo_style custom step atoms
dump 1 all custom 1000 mail.dump id type x y z
restart 1000 mail1.restart mail2.restart
run 30000
The restart input code:
read_restart mail1.restart
log 1.log.lammps
neighbor 0.3 bin
region box block 0 10 0 10 -5 25
fix 2 all nve
thermo 1000
dump 1 all custom 1000 mail.1.dump id type x y z
restart 1000 mail1.1.restart mail2.1.restart
timestep 0.2
run 30000
Best regards
