Problems with pair_style hybrid
I have been trying to use the pair_style hybrid option with reax/c and comb3, but have been having problems in both cases. I am using the latest available version compiled with the necessary packages (MANYBODY and USER-REAXC). The log with the error in both cases follows:
**Reax/c
LAMMPS (13 May 2014)
units real
boundary f f f
atom_style charge
read_data tubo1010Charge.data
orthogonal box = (-15 -15 -14.5618) to (15 15 35.4382)
2 by 2 by 2 MPI processor grid
reading atoms …
361 atoms
pair_style hybrid coul/cut 15.0 reax/c NULL
pair_coeff 1 2 coul/cut 15.0
pair_coeff 2 2 coul/cut 15.0
pair_coeff * * ffield.reax C NULL
ERROR: Pair coeff for hybrid has invalid style (…/pair_hybrid.cpp:351)
** COMB3
boundary f f f
atom_style charge
reading atoms …
361 atoms
pair_style hybrid comb3 polar_off coul/cut 15.0
pair_coeff * * ffield.comb3 C NULL
When I test the exact same input but with Tersoff potential I get no errors, therefore I believe the problem is specifically for these two pair styles. However, the manual says the most recent version should be able to do comb3 and reax/c calculations with pair_style hybrid. Has anyone successfully used this option yet?
Sincerely,
Eric
How many atom types are in your data file?
Only two. The problem was already fixed by Axel, though. I failed to notice that I had to add the name of the manybody potential to the pair_coeff command when coupling it with hybrid style.
Regards,
Eric
