Hello *,
I’m trying to run the example KRR script via the ‘matminer_example’ repo with no luck. The problem seems to be related to Pymatgen:
$ python kernel_ridge_SCM_OFM.py
/home/dennis/pymatgen/pymatgen/init.py:89: UserWarning:
Pymatgen will drop Py2k support from v2019.1.1. Pls consult the documentation
at https://www.pymatgen.org for more details.
at https://www.pymatgen.org for more details.""")
File “kernel_ridge_SCM_OFM.py”, line 11, in
from matminer.featurizers.structure import SineCoulombMatrix, OrbitalFieldMatrix
File “/usr/local/lib/python2.7/dist-packages/matminer/featurizers/structure.py”, line 17, in
from pymatgen.analysis.diffraction.xrd import XRDCalculator
File “/home/dennis/pymatgen/pymatgen/analysis/diffraction/xrd.py”, line 15, in
from .core import DiffractionPattern, DiffractionPatternCalculator, \
File “/home/dennis/pymatgen/pymatgen/analysis/diffraction/core.py”, line 50, in
class DiffractionPatternCalculator(abc.ABC):
AttributeError: ‘module’ object has no attribute ‘ABC’
Any Ideas?
-Dennis
