Problems with restart2data
Hi folks,
I’m trying to use the restart2data tool and received the following error:
[jzimmer]$ ~/lammps-atc/tools/restart2data four_bubble_setup.rst four_bubble_setup.data
Reading restart file …
WARNING Restart file version does not match restart2data version
restart2data version = 6 Feb 2012
ERROR: Invalid flag in header section of restart file 128
I checked and the LAMMPS version I’m using is marked as 17 Feb 2012, which should be compatible with this version of restart2data, no? Any ideas?
Jon Z.
Axel - any ideas on this - I think you were the last person
to edit restart2data.cpp. The 128 flag looks to
big to be keyword in the enum{} header, so I think
the format must be mis-matched ... (reading the wrong
field).
not yet. i've been catching up on pending
issues and this is on the list.
field).
yeah, something like that.
for certain i was the last to
mix up things in restart2data,
so i should sort it out as well.
jon, can you send me a simple input
that reproduces this, in case i cannot
reproduce it with the tests that i have?
thanks,
