pylammps - accessing the result of compute property/atom
I am trying to “incorporate” the following two LAMMPS commands to a PyLAMMPS script:
compute metal_id shell_atom property/atom id
dump myDump all custom 2 dump.atom id c_metal_id
where shell_atom is a group I have previously defined using a command that looks like “group shell_atom type 1”. Following the manual, the compute command can be written as
L.compute(" metal_id shell_atom property/atom id")
I would like to assign the c_metal_id in a python variable instead of writing it to a file. How can I do that? I have thought of the following commands:
L.variable("xxx atom c_ metal_id ")
L.run(0)
x = L.variables[‘xxx’]
but when executing I get the following message: “ERROR: Variable xxx: Compute used in variable between runs is not current (…/variable.cpp:1529)”
Thank you,
Evangelos
as a general rule, data from computes can only be accessed during runs, as they may be depending on data that has to be tallied during a force computation or similar, which will happen only during a run. a workaround in many cases has been to use an averaging fix, but averaging only over a single repeat, so that it acts as a cache.
in the particular case, there is not much of a point in using compute property/atom as an atom style variable function of: id*gmask(shell_atom) should have the same result.
Thanks a lot for the clarification ! I had overlooked gmask.
Evangelos
Στις Τετ, 20 Μαρ 2019 στις 3:43 μ.μ., ο/η Axel Kohlmeyer <[email protected]> έγραψε:
