python interface and periodic image flags
Hi - is the list of things that can be passed as the first argument (attribute name) to scatter_atoms() documented anyplace? I want to access the periodic image flags, and I’m not sure what string to pass. The "compute property/atom” documentation lists some things, but they don’t exactly map to scatter_atoms() arguments, for example property/atom has separate x, y, and z, but scatter atom has ‘x’ as a 3-vector of positions. I might guess that “i” would work, by analogy to property/atom’s ix, iy, and iz, but it’d be nice to have a complete list someplace.
By the way, the documentation page
http://lammps.sandia.gov/doc/Section_python.html
refers to scatter_coords() in one place. Is this just an outdated thing that hasn’t been updated?
​you'll find the list in the function
void *Atom::extract(char *name)
​in the file atom.cpp​
​as you can see, it matches strings with corresponding pointers. if those
pointers actually contain data, depends on ​the atom style in use. so you
need to be careful, as there may be many segfaulting landmines here.
​imageflags are a somewhat tricky thing in this, since all three components
are stored in a single integer. with the default settings, you have 3
10-bit signed integers stored in a 32-bit signed integer. with
-DLAMMPS_BIGBIG, you store 3 21-bit signed integers. so you need to so some
masking and bitshifting to compose and decompose the data that is stored.
LAMMPS Molecular Dynamics Simulator
​possibly. i'll have a look. thanks for reporting.
axel.​
yes, the scatter_coords() was an old reference - it is now scatter_atoms().
I updated the Section python doc page and the Section howto 6.19 section
on the LAMMPS lib interface to point to src/atom.cpp::extract() for a list
of possible names.
