Dear LAMMPS users,
I am trying to understand how charge equilibration methods works in LAMMPS, particularly qeq/point (the simplest one). I have gone through the code, I stuck at the position where H matix is computed. According to Rappe and Goddard paper, the coulomb potential (J_AB) between two charge centres have been calculated as 14.4/r (14.4 - constant is added for the unit conversion Angstrom into eV), where r is the distance between the centres A and B.
Inside fix_qeq_point.cpp file, I don’t see this conversion factor, instead I see 1/2r (inside compute_H). Could you please explain me about this 1/2r factor? Is this enough for the conversion into eV?
In my case, I consider two atoms (for e.g., LiCl) and try to equalize their electronegativities by changing their charge values (using excel), and compared with the charge values that obtained from simulations. I have got different charge values compared to simulation values when I use (14.4/r), however, when I use 1/2r, almost end up with the close electronegativity values.
Your reply will be helpful and clearly understand the charge model.
Thank in advance
Regards,
veera
