Dear colleagues,
Let us consider the system consisting of two parts complying one to
ReaxFF ('ReaxFF subsystem') and and the other to some non-reactive force
field ('non-ReaxFF subsystem'). We achieve this, say, with command
pair_style hybrid reax/c controlfile lj/cut/coul/long 10.0
Atomic charges in ReaxFF subsystem must be equilibrated with fix
qeq/reax, while charges in non-ReaxFF subsystem are immutable. 'The QEq
method minimizes the electrostatic energy of the system by adjusting
the partial charge on individual atoms based on interactions with their
neighbors.' (from http://lammps.sandia.gov/doc/fix_qeq_reax.html)
The question is:
does qeq/reax algorithm takes into account static charges of
neighbor atoms from non-ReaxFF subsystem during minimization of
electrostatic energy via adjusting atomic charges within ReaxFF
subsystem?
Vadim
Dear colleagues,
The question is:
subsystem?
you are worrying about the wrong problem. this is a bogus model. using
pair style hybrid causes more problems beyond charge equilibration.
1) how are you going to handle the "mixed" interactions between the reaxff
part and the class 1 force field part?
you cannot use the lj/cut lennard-jones parameters, since they are not
consistent with the reaxff charges.
2) also, how are you going to handle the long-range coulomb? kspace
interactions are not computed for pairs of atoms, but considers the
(long-range) coulomb interactions of each atom with *all* atoms in the
system and their (infinite) periodic replica. reaxff instead uses a
wolf-sum approximation to long-range coulomb, if i remember correctly.
to have a more consistent treatment of the interactions, you have to
follow an approach similar to what is done in QM/MM calculations. at the
very least you should implement an ONIOM-style mechanical coupling:
- you do a simulation of the *entire* system with lj/cut/coul/long and
kspace
- you do a simulation of the reaxff subsystem without the embedding
environment
- you do a simulation of the exact same subsystem but with lj/cut/coul/cut
now your total hamiltonian would be: U_total = U_all - U_lj/cut/coul/cut +
U_reaxff
this will still have some inconsistencies (e.g. the embedding environment
cannot polarize the reaxff subsystem - hence the term "mechanical
coupling").
if you want to handle than, you'd have to add an electrostatic embedding,
similar to QM/MM couplings, and even that is not fully consistent, since
your static system is non-polarizable, while the reaxff subsystem is, and
thus there is an non-physical unbalanced energy transfer during MD.
