I use qsub to submit jobs to a named queue, e.g.:
$ qsub -q atlas -l nodes=1:ppn=1 submit_script.sh
Where ‘-q atlas’ specifies that qsub should submit my job to the queue named ‘atlas.’ Following the queue tutorial (https://pythonhosted.org/FireWorks/queue_tutorial.html) I’m having trouble running “$ qlaunch singleshot” with the following error:
2017-01-23 11:39:42,254 INFO moving to launch_dir /atlas/u/jkuck/fireworks/fw_tutorials/queue/queue_tests
2017-01-23 11:39:42,256 INFO submitting queue script
2017-01-23 11:39:44,341 ERROR ----|vvv|----
2017-01-23 11:39:44,342 ERROR Error in job submission with PBS file FW_submit.script and cmd [u’qsub’, u’FW_submit.script’]
The error response reads: qsub: submit error (Unknown queue MSG=requested queue not found)
2017-01-23 11:39:44,342 ERROR ----|^^^|----
2017-01-23 11:39:44,342 ERROR ----|vvv|----
2017-01-23 11:39:44,343 ERROR Error writing/submitting queue script!
2017-01-23 11:39:44,343 ERROR Traceback (most recent call last):
File “/opt/rh/python27/root/usr/lib/python2.7/site-packages/fireworks/queue/queue_launcher.py”, line 135, in launch_rocket_to_queue
raise RuntimeError('queue script could not be submitted, check queue '
RuntimeError: queue script could not be submitted, check queue script/queue adapter/queue server status!
2017-01-23 11:39:44,343 ERROR ----|^^^|----
I think the problem may be I haven’t specified that my job should be run on the ‘atlas’ queue. Please let me know how to make this specification, or if the error message might indicate a different problem.
Jonathan
