continuing to the post above:
I think I have partially figured out the problem - the inconsistencies in formation energies come from applying the R2SCAN elemental energies to those entries still in the GGA/GGA+U level. For instance:
from monty.serialization import loadfn
from rxn_network.entries.entry_set import GibbsEntrySet
from pymatgen.analysis.phase_diagram import PhaseDiagram
from pymatgen.core.periodic_table import Element
# pre-downloaded entries files using MPRester().get_entries_in_chemsys("Na-Mn-O-N-H")
old = loadfn("data/entries/computed_str_entries_Na_Mn_O_N_H_2021_11_10.json.gz")
new = loadfn("data/entries/computed_str_entries_Na_Mn_O_N_H_2022_10_28.json.gz")
when E_f is calculated using the old entries:
def calculate_formation_energies(entries):
e_set = EntrySet(entries)
pd = PhaseDiagram(e_set)
for e in pd.all_entries:
if e.composition.reduced_formula == "NaMnO2":
print("="*70)
print(f"id: {e.entry_id} | "
f"comp: {e.composition} | "
f"e_f: {pd.get_form_energy_per_atom(e)} | "
print(pd.el_refs[Element("Mn")])
calculate_formation_energies(old)
which outputs:
id: mp-1016119 | comp: Na4 Mn4 O8 | e_f: -1.9337249892456905 |
id: mp-21036 | comp: Na2 Mn2 O4 | e_f: -2.01750219987069 |
id: mp-18957 | comp: Na4 Mn4 O8 | e_f: -2.0304508867456894 |
id: mp-1016152 | comp: Na4 Mn4 O8 | e_f: -1.94778660237069 |
id: mp-759533 | comp: Na4 Mn4 O8 | e_f: -1.999933541120689 |
id: mp-971647 | comp: Na2 Mn2 O4 | e_f: -1.922209088620689 |
id: mp-1272321 | comp: Na4 Mn4 O8 | e_f: -2.01618848049569 |
id: mp-755160 | comp: Na2 Mn2 O4 | e_f: -1.9173198961206905 |
id: mp-755520 | comp: Na2 Mn2 O4 | e_f: -1.9725229811206892 |
id: mp-578605 | comp: Na1 Mn1 O2 | e_f: -1.933809993620689 |
id: mp-1283729 | comp: Na4 Mn4 O8 | e_f: -2.0061234854956895 |
mp-35 ComputedStructureEntry - Mn29 (Mn)
Energy (Uncorrected) = -265.6984 eV (-9.1620 eV/atom)
Correction = 0.0000 eV (0.0000 eV/atom)
Energy (Final) = -265.6984 eV (-9.1620 eV/atom)
Energy Adjustments:
None
Parameters:
potcar_spec = [{'titel': 'PAW_PBE Mn_pv 07Sep2000', 'hash': 'fa52f891f234d49bb4cb5ea96aae8f98'}]
is_hubbard = False
hubbards = {}
run_type = GGA
Data:
oxide_type = None
aspherical = True
last_updated = 2021-02-05 11:07:18.085000
task_id = mp-1814312
oxidation_states = {}
run_type = GGA
However, when using the new entries:
calculate_formation_energies(new)
# Output
id: mp-18957-GGA+U | comp: Na4 Mn4 O8 | e_f: 0.41287982075431096 |
id: mp-578605-GGA+U | comp: Na1 Mn1 O2 | e_f: 0.5095207138793114 |
id: mp-18957-R2SCAN | comp: Na1 Mn1 O2 | e_f: -2.1169164336206894 |
id: mp-755160-GGA+U | comp: Na2 Mn2 O4 | e_f: 0.5260108113793098 |
id: mp-1283729-GGA+U | comp: Na4 Mn4 O8 | e_f: 0.43720722200431084 |
id: mp-971647-GGA+U | comp: Na2 Mn2 O4 | e_f: 0.5211216188793113 |
id: mp-21036-R2SCAN | comp: Na2 Mn2 O4 | e_f: 0.42582850762931024 |
id: mp-759533-GGA+U | comp: Na4 Mn4 O8 | e_f: 0.44339716637931126 |
id: mp-1016152-GGA+U | comp: Na4 Mn4 O8 | e_f: 0.49554410512931035 |
id: mp-1016119-GGA+U | comp: Na4 Mn4 O8 | e_f: 0.5096057182543099 |
id: mp-1272321-R2SCAN | comp: Na4 Mn4 O8 | e_f: 0.42714222700431037 |
id: mp-755520-GGA+U | comp: Na2 Mn2 O4 | e_f: 0.4708077263793111 |
id: mp-21036-GGA+U | comp: Na2 Mn2 O4 | e_f: 0.42582850762931024 |
id: mp-1272321-GGA+U | comp: Na4 Mn4 O8 | e_f: 0.42714222700431037 |
mp-35-R2SCAN ComputedStructureEntry - Mn29 (Mn)
Energy (Uncorrected) = -425.8167 eV (-14.6833 eV/atom)
Energy (Final) = -425.8167 eV (-14.6833 eV/atom)
Energy Adjustments:
None
Parameters:
potcar_spec = [{'titel': 'PAW_PBE Mn_pv 02Aug2007', 'hash': '9fc2da19948217b93232c1ff13eec3a6'}]
is_hubbard = False
hubbards = {}
run_type = R2SCAN
Data:
oxide_type = None
aspherical = True
last_updated = 2021-07-25 12:17:10.051000
task_id = mp-2739260
material_id = mp-35
run_type = R2SCAN
Most of the E_f turned positive as they were calculated with respect to the new Mn entry (mp-35-R2SCAN) which has much lower energy (-14.6833 eV/atom).
Since I have already done most of my calculations using the 2021 database, my temporary solution to this problem is to remove the entries with R2SCAN corrections:
filtered_new = []
for e in new:
names = [adj.name for adj in e.energy_adjustments]
if 'MP GGA(+U)/R2SCAN mixing adjustment' not in names and "R2SCAN" not in e.entry_id:
filtered_new.append(e)
calculate_formation_energies(filtered_new)
The only concern I have is the numbers of entries do not match anymore:
print(len(old))
print(len(filtered_new))
# Output
504
444
So it would be great if there’s a more elegant way of handling different database versions in the new API.
Jiaxin
