Hi Steve,
I have a simple query regarding placing an impurity on a simple lattice. For example,
To specify the bcc lattice i used the following command.
lattice custom 1 a1 1 0 0 a2 0 1 0 a3 0 0 1 origin 0 0 0 basis 0 0 0 basis 0.5 0.5 0.5.
Now i wish to create only single impurity on single face of cube so i specified.
lattice custom 1 a1 1 0 0 a2 0 1 0 a3 0 0 1 origin 0 0 0 basis 0 0 0 basis 0.5 0.5 0.5 basis 0.5 0.5 0
which created two impurities on both faces. How can one of them be deleted & bulk be generated.
Regards,
Saurav
I can't tell if you are trying to define two different lattices
and create 2 different sets of atoms. The usual way
to do this is to define one lattice with all the atoms of
both types in the basis.
Then with the create_atoms command you can create
two types of atoms at once, using its "basis" keyword
to specify different atom types for different basis sites
in the lattice definition.
Hi Steve,
I think you got me wrong. Let me simplify.
It will create a bcc lattice + 2 atoms on faces as shown in attached snap(before.jpg)
However, I wish to have only one atom on the face as shown in attached snaps(after.jpg) & to generate a bulk. How should i do it.
Regards,
Saurav
If i specify
Hi Steve,
Regards,
Saurav
If i specify
If your unit cell is the cube in the picture, then it's not possible
to define a basis atom on a face that won't be on multiple faces
in the replicated lattice. That's not what a unit cell and basis
atoms mean. You'd have to define a 2nd lattice with a larger unit
cell and put the impurity atom in the middle of the larger cell
to get what you want. Which you can easily do with LAMMPS.
