Hi, When I try to download data to construct the phase diagram by using the following query
data = MPRester(“my_api_key”).get_entries_in_chemsys([“Fe”, “P”, “O”], compatible_only=True)
It reports the following:
KeyError Traceback (most recent call last)
in
----> 1 data = MPRester(“DlBMToO6iyQfUv0N”).get_entries_in_chemsys([“Fe”, “P”, “O”], compatible_only=True)
~/anaconda3/lib/python3.8/site-packages/pymatgen/ext/matproj.py in get_entries_in_chemsys(self, elements, compatible_only, inc_structure, property_data, conventional_unit_cell)
709 all_chemsyses.append(’-’.join(sorted(els)))
710
–> 711 entries = self.get_entries({“chemsys”: {"$in": all_chemsyses}},
712 compatible_only=compatible_only,
713 inc_structure=inc_structure,
~/anaconda3/lib/python3.8/site-packages/pymatgen/ext/matproj.py in get_entries(self, chemsys_formula_id_criteria, compatible_only, inc_structure, property_data, conventional_unit_cell, sort_by_e_above_hull)
420 d[“potcar_symbols”] = [
421 "%s s" (d[“pseudo_potential”][“functional”], l)
–> 422 for l in d[“pseudo_potential”][“labels”]]
423 data = {“oxide_type”: d[“oxide_type”]}
424 if property_data:
KeyError: ‘labels’
It seems the labels are not as the key in the dictionary, but it works for next system like [“Hf”, “Ge”, “Te”]. Could you please provide some suggestions on this? Thanks.
