I am trying to use “additions” and “detours” of FWAction, but I have encountered two unexpected behaviors.
I am not sure that I’m doing correct things, so please correct or advise me if I’m wrong.
My test script is as follows;
my_fw_for_fwaction.py:
import os
from fireworks import explicit_serialize, FiretaskBase, FWAction, Firework
from fireworks.features.dupefinder import DupeFinderBase
path = [os.path.dirname(file)]
@explicit_serialize
class PrintTask(FiretaskBase):
required_params = [“name”]
def run_task(self, fw_spec):
print("---self---\n")
for k in self.keys():
print("{}: {}\n".format(k, self[k]))
print("---fw_spec---\n")
for k in fw_spec.keys():
print("{}: {}\n".format(k, fw_spec[k]))
return FWAction()
@explicit_serialize
class AdditionsTask(FiretaskBase):
required_params = ["name", "parents"]
new_spec = fw_spec if fw_spec else {}
new_spec["added"] = True
print(new_spec)
tasks = [PrintTask(name="Additions")]
return FWAction(additions=[Firework(tasks,
spec=new_spec,
parents=self["parents"])])
class MyDupeFinder(DupeFinderBase):
_fw_name = ‘MyDupeFinder’
def verify(self, spec1, spec2):
return True
def query(self, spec):
print("query called!")
return {"$and": [{"launches": {"$ne": []}}]}
class FirstFW(Firework):
_fw_name = “FirstFW”
def init(self, parents=None):
self._task = [PrintTask(name="fw1_print"),
AdditionsTask(name="add1", parents=self)]
super().__init__(self._task, parents=parents, name=self._fw_name,
spec={"_dupefinder": MyDupeFinder()})
class SecondFW(Firework):
_fw_name = “SecondFW”
self._task = [PrintTask(name="fw2-print")]
super().__init__(self._task, parents=parents, name=self._fw_name)
add_wf_to_lpad.py:
from future import division, unicode_literals, print_function
from fireworks import LaunchPad, Workflow
from my_fw_for_fwaction import FirstFW, SecondFW
lpad = LaunchPad.auto_load()
def add_wf(name):
first = FirstFW()
second = SecondFW(parents=first)
wf = [first, second]
wf = Workflow(wf, name=name)
lpad.add_wf(wf)
if name == “main”:
add_wf(“test”)
Command I executed on terminal:
lpad reset
python add_wf_to_lpad.py
rlaunch singleshot
rlaunch singleshot
1st problem:
When I wrote script and executed add_wf_to_lpad.py, error as following occurs.
File “add_wf_to_lpad.py”, line 20, in
add_wf(“test”)
File “add_wf_to_lpad.py”, line 16, in add_wf
lpad.add_wf(wf)
File “/usr_psi/local/lib/python3.6/dist-packages/fireworks/core/launchpad.py”, line 320, in add_wf
old_new = self._upsert_fws(list(wf.id_fw.values()), reassign_all=reassign_all)
File “/usr_psi/local/lib/python3.6/dist-packages/fireworks/core/launchpad.py”, line 1352, in _upsert_fws
self.fireworks.insert_many((fw.to_db_dict() for fw in fws))
File “/home/common/virtualenv/python3.6/lib/python3.6/site-packages/pymongo/collection.py”, line 752, in insert_many
blk.ops = [doc for doc in gen()]
File “/home/common/virtualenv/python3.6/lib/python3.6/site-packages/pymongo/collection.py”, line 742, in gen
for document in documents:
File “/usr_psi/local/lib/python3.6/dist-packages/fireworks/core/firework.py”, line 301, in to_db_dict
m_dict = self.to_dict()
File “/usr_psi/local/lib/python3.6/dist-packages/fireworks/utilities/fw_serializers.py”, line 141, in _decorator
m_dict = func(self, *args, **kwargs)
File “/usr_psi/local/lib/python3.6/dist-packages/fireworks/core/firework.py”, line 257, in to_dict
spec[’_tasks’] = [t.to_dict() for t in self.tasks]
File “/usr_psi/local/lib/python3.6/dist-packages/fireworks/utilities/fw_serializers.py”, line 168, in _decorator
File “/usr_psi/local/lib/python3.6/dist-packages/fireworks/utilities/fw_serializers.py”, line 142, in _decorator
m_dict = recursive_dict(m_dict)
File “/usr_psi/local/lib/python3.6/dist-packages/fireworks/utilities/fw_serializers.py”, line 83, in recursive_dict
for k, v in obj.items()}
File “/usr_psi/local/lib/python3.6/dist-packages/fireworks/utilities/fw_serializers.py”, line 76, in recursive_dict
return recursive_dict(obj.as_dict(), preserve_unicode)
File “/usr_psi/local/lib/python3.6/dist-packages/fireworks/utilities/fw_serializers.py”, line 212, in as_dict
return self.to_dict()
… (very long error message, but simply repeated)
RecursionError: maximum recursion depth exceeded while calling a Python object
When I specified parents=None in FirstFW, instead of parents=self, this problem was solved.
Don’t I need to specify added task’s “parents”?
2nd Problem:
Even I rewirted FirstFW as above (parents=self -> parents=None), the second rlaunch fails.
The output is as follows;
rlaunch singleshot
2018-12-15 19:28:37,542 INFO Hostname/IP lookup (this will take a few seconds)
2018-12-15 19:28:37,543 INFO Launching Rocket
query called!
2018-12-15 19:28:37,596 INFO Duplicate found! fwids 3 and 2
query called!
2018-12-15 19:28:37,623 INFO Duplicate found! fwids 4 and 3
query called!
2018-12-15 19:28:37,654 INFO Duplicate found! fwids 5 and 4
query called!
(…infinite loop)
Even I used “detours” instead of “additions”, the same problem occurred.
I will appreciate any helps and advices.
Akira Takahashi
