question about fix setforce
I use “fix setforce” command on a group of atoms but I want to know if there is a way to extract the force(s) on these atoms from other atoms outside the group (I mean force before it is zeroed by fix setforce).
thanks,
Anurag
See the bottom of the fix setforce doc page. The
fix stores exactly the quantity you are asking about,
which can be output.
Hello Everyone,
I had a question regarding generation of a parallelepiped using “region prism” command.
is there a reason to allow only 3 “tilt factors” ?
right now the documentation says the allowed “tilt factors” are xy, xz and yz. I was wondering why a factor such as zx is not allowed ?
thank you.
regards,
Anurag
Hello Everyone,
I had a question regarding generation of a parallelepiped using "region
prism" command.
is there a reason to allow only 3 "tilt factors" ?
that is sufficient to describe all meaningful system cells.
right now the documentation says the allowed "tilt factors" are xy, xz and
the implementation for non-orthogonal cells requires
the first axis of the system cell being collinear with the
the x-axis, the second axis to be in the xy plane and
the third chosen so that you get a right-handed coordinate
system. that limits the choices to these three.
Another way to look at it, is that any general parallelpiped
can be rotated to be compatible with the 3 tilt
factors that LAMMPS allows.
I am running a simulation wherein MS static runs follow a MD (NVE+Langevin thermostat) run.
I see LAMMPS prints a warning saying :
WARNING: Resetting reneighboring criteria during minimization (min.cpp:167)
what does this imply ? this seems to imply that neighbour list settings specified for MD run are reset but what are the changed settings for building neighbor lists?
thanks.
thermostat) run.
the changed settings are
neigh_modify delay 0 every 1
the original settings are stashed away and
then restored at the end of the minimization.
btw: this topic was explained on this very
mailing list recently already.
