Question about harmonic constraint in fix colvars
Dear All,
I use the 1_Mar_2016 version on Unix cluster to run steered MD (pulling one I atom away from the surface) using fix colvars command. The I atom is only allowed to freely move along the pulling direction (z axis). The position of I atom is (25.125533, 19.449313, 73.174075). And the total system has been equilibrated already.
group I id 1676
velocity I set 0.0 0.0 NULL
variable x equal (xcm(I,x))
variable y equal (xcm(I,y))
variable z equal (xcm(I,z))
thermo 100
thermo_style custom step v_x v_y v_z
thermo_modify flush yes
fix nvt all nvt temp $T $T 100
fix smd all colvars I.colvars tstat nvt
fix f I setforce 0.0 0.0 NULL
run 50000
Firstly, I only add a harmonic constraint between I atom and a fix point (dummyatom). If I use a smaller forceconstant (20), the job runs but I atom fluctuates severely (z increases from 73 to 112). If I use a larger forceconstant (1000), the job is terminated with the error of atom missing. My question is what reason may cause these problems? The I.colvars file is:
# Steered MD simulation for PMF calculation
colvarsTrajFrequency 1000
colvarsRestartFrequency 1000
colvar {
name I
outputAppliedForce on
distance {
group1 {
atomNumbers 1676
group2 {
dummyAtom (25.125533, 19.449313,)
harmonic {
name PMF
colvars I
centers 20
forceConstant 20.0
# targetCenters 0.0
# targetNumSteps 3000
outputEnergy on
outputCenters on
# outputAccumulatedWork on
MC
Dear All,
​if you have a soft spring, the atom​ can more around, if you have a stiff
spring, you probably need to reduce the length of tour time step, as steep
potentials require a better resolution in time integration.
