Dear Everyone,
I am trying to modify the soft segmental repulsive potential from a simple expression to a complex LJ expression. I modified all the corresponding expressions of energy and force in the pair_srp.cpp file. When I compiled and run it, it was terminated with the error: Illegal fix_modify command.
In modify.cpp, narg<2 leads to the error. However, when I checked the fix_srp.cpp file, it didn’t find fix_srp links to the modify_fix function. I am just wondering is there any possible reason can that lead to such error?
Kind regards,
Mingchao
pair_srp.cpp (22.3 KB)
Dear Everyone,
please note that this code is currently being refactored to address
some restarting and general implementation issues.
BTW: that code is going to run needlessly slow due to the redundant
use of the pow() function.
fix_srp.cpp file, it didn't find fix_srp links to the modify_fix function. I
of course not. that wouldn't work. pair srp communicates changes and
setting to fix srp via the fix->modify_params() API.
how about some incorrect fix_modify command elsewhere that has nothing
to do with SRP.
Dear Alex,
I didn’t use any fix_modify command in my input file. I used thermo_modify and dump_modify, is that possible these command lead to the error?
Kind regards,
MC
Dear Alex,
I didn't use any fix_modify command in my input file. I used thermo_modify
no. it is trivial to find out which command is causing the problem, as
it is the last command shown on the screen with -echo screen before
LAMMPS abends.
I have checked it with echo command, and fix_nvt command led to the error. Here is the content of my input file:
units real
echo screen
atom_style angle
read_data test.data
bond_style harmonic
bond_coeff * 200.0 100.0
angle_style harmonic
angle_coeff * 4500.0 180.0
pair_style hybrid lj/cut 100.0 srp 100.0 1 min exclude yes
pair_coeff 1 1 lj/cut 108.0000 22.630000
pair_coeff 1 2 none
pair_coeff 2 2 srp 108.000 22.630 100.0
special_bonds lj 0.0 0.0 0.0
replicate 333 10 1
neighbor 2.0 bin
neigh_modify delay 20 every 20 check yes
variable t equal 2000
well, then you know what you have to debug.
