Dear Lammps Users,
When I try to investigate the thermal conductivity of graphene, I want to try the NEMD method by integrating hot/cold reservoir with NVT ensemble, and the sample with NVE to reach a steady T gradient. However, I can’t figure out how to get the value of heat flow.
By reading NVT’s instruction, I find
- PE_eta[tchain] = potential energy of each particle thermostat displacement (energy units)
- KE_eta_dot[tchain] = kinetic energy of each particle thermostat velocity (energy units)
I wonder if I should sum these six terms (for tchain=3 as default), and devided by the timestep to get the heat flow (or say the power of heat bath)?
I know the other 4 methods and just want to try this one.
Any suggestions will be appreciated.
Thank you very much.
Sincerely,
Yuan Gao
Dear Lammps Users,
the sample with NVE to reach a steady T gradient. However, I can't figure
By reading NVT's instruction, I find
(energy units)
(energy units)
bath)?
i just answered the very same question in response to a different
e-mail with the same question (is that a coincidence?).
please check that response.
