Hello everyone,
I am using Lammps 14May-2016 version. I will describe my system first before asking my question. Basically it is a bead spring model. I have 4 beads to make up one chain. And there are many chains arranged together in a bundle. All the beads are of the same atom type and have the same mass.
Besides the harmonic bond style, angle style and dihedral styles, there are lj 6-12 potential fit between each beads in a chain and a lj 9-6 potential between beads in the adjacent chains.
Now my question is by specifying a command like “pair_coeff 1 1 100.0 3.5 9.0” , I can specify the interactions between beads in each of the chains. However what do I do for capturing the lj 9/6 potential which is basically between chains?
I thought of one solution. I can change the atom types in each chain and modify the data file. For example, if there are 8 chains I can have atom types 1-8. The lj9/6 can be captured by using something like the “pair_coeff 1 2 100.0 3.5 9.0” and so on. However, the problem is if I have many chains (around 50), it is very tedious to capture each cross term pair_Coeff command. Is there a better way for this? Any feedback will be much appreciated.
Thank you so much for your help.
Regards,
Hello everyone,
Now my question is by specifying a command like "pair_coeff 1 1 100.0 3.5
9.0" , I can specify the interactions between beads in each of the chains.
between chains?
"pair_coeff 1 2 100.0 3.5 9.0" and so on. However, the problem is if I have
much appreciated.
please check, if i do understand you correctly:
- a "molecule" would be a 4-bead chain
- the 12-6 LJ terms are only for *intra*molecular pairs
- the 9-6 LJ terms are only for *inter*molecular pairs
- you are currently using special_bonds lj/coul 1.0 1.0 1.0
if yes, i may have a suggestion for you.
if no, please try explaining again
You are totally correct in understanding the problem. Please do provide your feedback. Thank you so much.
ok. then i would suggest the following.
- define the pair style only for the *inter*molecular interactions, i.e.
lj9-6 interactions.
- use "neigh_modify exclude molecule/intra all" to turn off those
interactions within each molecule
- switch your bond style to using hybrid combining your current bond style
with bond style table
- create a table for bond style table, that has the desired 12-6 LJ
intra-molecular potential.
- define *additional* bonds for all intramolecular pairs and use the bond
table on those
