Question about pair style gauss
Dear lammps developers,
I’m a little confused about signs in gauss and gauss/cut potential.
In gauss:
if (eflag)
evdwl = -(a[itype][jtype]*exp(-b[itype][jtype]*rsq) - offset[itype][jtype]);
In gauss/cut:
ugauss = pgauss[itype][jtype]exp(-0.5rexp*rexp);
if (eflag) {
evdwl = ugauss - offset[itype][jtype];
evdwl *= factor_lj;
So, positive A corresponds to negative E in pair style gauss and positive H/sigma corresponds to positive E in pair style gauss/cut.
Is that correct? If yes, formula on doc page need to be change.
Also, I’ve found a small bug on http://lammps.sandia.gov/doc/pair_gauss.html: links to (Lenart) and (Jusufi) are broken.
Regards,
Grigory
The 2 gauss versions were developed independently, so they
may have different sign conventions. I'll let Axel comment.
Grigory - I agree with you that the doc page formula for pair gauss needs
a minus sign. Just made the change. So the 2 gauss pair styles do
have different sign conventions. I think the code for both thus requires
no change. Do you agree?
Axel, there are 2 citations in the doc text for pair gauss/cut that are not
listed at the bottom of the page ...
Yes, I agree with you. pair/gauss is useful for creating potential wells, thus minus sign in formula is more convenient. And this is implemented in the current code.
Regards,
Grigory
2012/10/1 Steve Plimpton <[email protected]>
