Though the forward / reverse comm is declared in comm.h as below
virtual void forward_comm_pair(class Pair *) = 0;
virtual void reverse_comm_pair(class Pair *) = 0;
I find nowhere they are really defined, except in comm_brick.cpp and comm_tiled.cpp.
For example, when I read **src/**MANYBODY/pair_eam.cpp and see the following
if (newton_pair) comm->reverse_comm_pair(this);
how can I trace where the above reverse_comm_pair is really defined?
Thanks for any comment!
Best regard,
Yidong
It depends on your comm style, and comm_brick is the default style.
Ray
comm_tiled.cpp.
yes, please grab your favorite text book on C++ programming, look up
"polymorphism", "virtual methods", and "pure methods" and then compare
what you learn there witH the LAMMPS code. you'll quickly see it all
makes a lot of sense.
By the way, what is being communicated is defined by each of the pair, fix, etc, styles.
