I have a question about bond style fene. Is this the order that the parameters must be placed in the input script for bond_coeff?
bond_coeff K(energy/distance^2) R0(distance) epsilon(energy) sigma(distance) (for the fene bond).
Also, for lj cut/ in the input script, for pair coeff, do I put the parameters in this order?
pair_coeff epsilon(energy) sigma(distance)? (for lj/cut)
Finally, the fene bond potential also includes the lennard jones potential in its formulation, in addition to the nonlinear spring part. Does that mean that atoms that are bonded together will experience two lennard jones potentials, the one that I specified in lj / cut and the one that is automatically specified in the fene bond? Or does the fene bond lennard jones part overwrite the lennard jones specified in lj/cut for atoms that are bonded together? I could not find this answer on the website.
Thank you
have a look at:
depends on your exclusions settings.
no. see the special_bonds command documentation.
everything you ask about is documented clearly in the lammps manual.
what the lammps manual is not, is a textbook on how to implement
and perform MD simulations. there are a ton of those around.
