Hi all,
yes, my concern is the total electrostatic energy difference between this two packages, the real space cutoff are 12 A, and long range accuracy 1e-12, both in GULP and lammps, and i have tried to increase the cutoff and accuracy, the energy is still there. GULP doc say the real part energy has a erfc function, and the eta is a dumping function (as in the picture in previous email), but in lammps doc for (coul/long), no erfc function act on the coulomb formula.that is best reason i have now. any ideas?
Best Regards
Jiasen Guo
Hi all,
your conclusion is not correct. there is *of course* an erfc()
function applied in coul/long. otherwise the whole thing would not
work.
you cannot see a call to erfc() in the source, since it is
approximated by a polynomial formula or tabulation.
...and it turns out that in the documentation file itself the
expression for coul/long is simply not represented.
any ideas?
Have you turned off tabulation using "pair_modify table 0"? Next would be to use an exact representation of erfc instead of the polynomial expansion. See previous mail list posts on this topic.
Stan
