Hi lamps-users,
I was curious about what is going on at some point in the build when a copy of /src/USER-ATC/fix_atc.cpp was made in /src/fix_atc.cpp. I do not see the latter in the original git download. Can someone explain what is going on?
Thank you,
Stephen Thomas.
Hi lamps-users,
that is just how LAMMPS' build system works. only sources in the src
directory are considered for compilation. thus when installing a
package, the selected source files from the package subdirectory are
copied into src. similarly, they get deleted when uninstalling. the
git/svn repository has no packages installed by default.
Thanks for that explanation Dr. Kohlmeyer.
