Hi folks!
How to use atom information stored by fix_store_state command in a *.cpp file,eg.impoper.cpp.
Thank you,
Younggung
Hi folks!
Thank you,
Younggung
three comments.
to avoid confusion, please don’t use the term ‘potential files’ if you are talking about source code. in the context of LAMMPS the term ‘potential files’ refers to files with parameters like the ones in the ‘potentials’ folder.
if you want to know how to do things in the source code, you have to read and study the source code. there are lots of examples of commands that access externally defined fixes and computes (you can look those up in the manual), but there are also some commands that generate and use fixes internally. those don’t use fix store/state, but the (internal-only) fix STORE. here are the files (they can be easily found through grep -l '"STORE"' *.cpp */*.cpp
balance.cpp
compute_chunk_atom.cpp
compute_displace_atom.cpp
compute_msd_chunk.cpp
compute_msd.cpp
compute_vacf.cpp
dump_custom.cpp
fix_adapt.cpp
variable.cpp
CORESHELL/compute_temp_cs.cpp
REPLICA/tad.cpp
USER-FEP/fix_adapt_fep.cpp
USER-MISC/compute_hma.cpp
please don’t modify core files like improper.cpp. that is most likely going to cause problems down the road.
