Question about using r-respa integrator
I would like to model flexible water, co2 and solid surfaces in my system with LAMMPS, which requires a very small time step (for flexible water), i.e. dt = 0.25 fs. I think r-respa may be one way to speed up the simulation. According to the LAMMPS document, it suggests using the following setup, so that the innermost time step is 0.5 fs:
timestep  4.0
run_style respa 4 2 2 2 inner 2 4.5 6.0 middle 3 8.0 10.0 outer 4
I will try this set up in my simulations with timestep = 2 fs so that the innermost timestep is 0.25 fs (for bonds and angles) . My question is: apart from checking the energy conservation, is there any “pitfalls” about using the r-respa method in molecular dynamics simulations that I should pay attention to? It will be great if anyone who has had experiences with the r-respa method can provide any comments, suggestions or hints. All comments are welcome.
Thank you for your time.
Regards,
Pengyu
timestep 4.0
from checking the energy conservation, is there any "pitfalls" about using
are welcome.
you are confusing multi-cutoff separation with bond/angle/pair separation.
you are not going to save much time with your setup from above, since
you are computing a lot of interactions multiple times.
you probably want something like this:
timestep 4.0
run_style respa 3 4 2 dihedral 1 pair 2 kspace 3
however, the biggest problem is not the flexible water, but the co2.
for that you would need a rigid integrator and those will require a
short time step anyway to run stable.
so using r-RESPA may not be as helpful as you expect.
