I am trying to perform an uniaxial test of a copper nanowire.
As I have read in some emails before I can’t use fix deform because my system hasn’t got periodic boundary conditions.
I am using velocity command in the upper and lower layers of atoms but when I run the simulation the values of lx, ly and lz are always the same, so it doesn’t move at all.
Do I need to set the force to 0.0? If not, have you got any other suggestion to perform this`kind of simulation?
and the second question, what information do I need to compute to find the Young Modulus?
here is my input script,
boundary s s p
atom_style atomic
variable latconst equal 3.615
lattice fcc {latconst}
region nanowire block 0 20 0 20 0 6
create_box 3 nanowire
lattice fcc {latconst} orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
create_atoms 1 region nanowire
pair_style eam
pair_coeff * * Cu_u3.eam
neigh_modify delay 0 every 1 check yes page 100000 one 2000
region upper block INF INF 59.7 INF INF INF units box
group upper region upper
region lower block INF INF INF 12.66 INF INF units box
group lower region lower
group boundary union lower upper
group middle subtract all boundary
set group lower type 2
set group upper type 3
compute centrosym all centro/atom fcc
compute ss all stress/atom virial
compute new middle temp
velocity middle create 300 12345 temp new
velocity upper set 0.0 +0.01 0.0
velocity lower set 0.0 -0.01 0.0
fix 1 all nvt temp 0.01 0.01 1
fix 4a lower setforce 0.0 0.0 0.0
fix 4b upper setforce 0.0 0.0 0.0
timestep 0.01
thermo 500
thermo_style custom step lx ly lz press pxx pyy pzz pe temp
run 1000000
Thank you,
Gemma
