Hello!
I combine the Kremer-Grest model with fix deform + nvt/SLLOD command
Just like
fix 1 all nvt/sllod temp 1.0 1.0 1.0 tchain 1
fix 2 all deform 1 xy erate ${Rate} units box remap v
and other codes are same as the input script in bench folder
In manual, it is said the stream velocity has been removed.
However, I found the velocity of system center of mass in flow direction, i.e. the sum all particle’s, is not “zero”, it increases with strain and is related to shear rate
So, I want to confirm if I miss some details in my script or it is the truth in this problem
By the way,
if combine the Kremer-Grest model with DPD, and fix comands are changed by
fix 1 all nve
I also found the velocity of system center of mass in flow direction is not “zero”, but it is not increases with strain
So, if someone talk about this problem before?
Sincerely
Yongjin Ruan
