Dear lammps members,
SHAKE in LAMMPS is limited to small clusters, like water,
or CH bonds in a polymer chain.
If you can use fix shake to rigidify your model (e.g. water),
then you should use it. If you can’t b/c the molecule or cluster
is too big, then use fix rigid or fix rigid/small.
Thank you for the suggestion.
I did not use " fix rigid" or " fix rigid/small" since they ate NVE time stepping, and I needed
NVT equilibriation.
and I wanted to find if one is preferable over the other.
NVT equilibriation.So I tested " fix nvt + fix shake" and “fix rigid/nvt” – both seems to work,
Fix shake usually allows a larger timestep.
Thank you.
regards
shankar
Hi Shankar,
fix rigid/small/nvt and other variants are underway. For now, you can use fix rigid/small coupled with fix langevin as an alternative to sample the NVT ensemble.
You can try yourself to see if the time step for rigid/small + langevin should be smaller than fix shake + fix nvt for your particular simulations.
-Trung
Dear Trung,
Thank you for the suggestions.
For now I am testing methods for nvt equilibriation of nitrogen molecules; later, study it for
computing drag on cnt in nitrogen flow.
I briefly looked up references on “time-integrators” ( lammps doc: Kamberaj 2005 for rigid/nvt) and others; but I am not yet well versed them and I wanted to learn from the experience of lammps users for their specific problems/issues
I will study “rigid/small + langevin” as you suggest.
