Dear LAMMPS users and developers,
I have a short question regarding pre-build binary packages for CentOS (I need to give instruction to the facility super-computer authority to install LAMMPS-2015).
Does the pre-build binary files provided in (http://rpm.lammps.org/centos/) contain all standard packages including REPLICA? or do I need to add this package manually?
I have read the contents of (http://rpm.lammps.org/), which clearly states that all optional packages are included in the source distribution except, GPU, KIM, KOKKOS, REAX, USER-CUDA, and USER-INTEL, but I want to make sure, before preparing the instruction.
LAMMPS-2015).
package manually?
the pre-built binary packages have not been updated for a while due to
the LAMMPS workshop.
since there were several new additions, those are not yet contained in
the binaries.
in any case, i think this is going to be pointless, then any
self-respecting super-computing center will insist on building
binaries from source with optimization and a configuration adapted to
their local environment, compilers and communication libraries. the
pre-built rpms _may_ work, but only if the compute nodes are 100% only
running standard CentOS rpms and no self-compiled/installed pacakges.
