Question on compute temp and compute temp/deform
Hi All,
I have a question about biases in thermostats due to streaming velocities of atoms.
If I’m deforming and thermostatting the box as follows:
“fix fxnvt all nvt/sllod temp 298 298 100.0
fix fxdfm all deform 1 xy wiggle {ampl} {tperiod} units box remap v”
and then calculate the temperature:
“compute cmp0 all temp”
Will the temperature calculated be the same as that calculated by fix nvt/sllod?
I ask this because a section in the manual states that incorrect use of compute temp/deform actually adds the bias back in to the computation, rather that takes it out.
Regards,
Tim.
Hi All,
of atoms.
If I'm deforming and thermostatting the box as follows:
"fix fxnvt all nvt/sllod temp 298 298 100.0
fix fxdfm all deform 1 xy wiggle \{ampl\} {tperiod} units box
remap v"
"compute cmp0 all temp"
nvt/sllod?
​no.
axel.​
This is explained on the fix nvt/sllod doc page (likewise for other
thermostatting fixes). It creates its own compute temp/deform.
You can query the output of that compute (or multiple compute temp
comands) in your thermo output.
