I am recently trying to do fracture simulation with modified morse potential, such that morse potential added with a angle potential term. For simplicity, I just chose harmonic angle style. The morse bond will break beyond its cut off radius, but the angle interaction remains. I wonder is there any way to set a cut off to angle potential? For example, the angle is denoted as \theta_ijk, where j is the center atom, can I set that once r_ij or r_jk is larger than a critical value, which may be the same value as that of morse, the angle interaction is turned off?
I am not sure whether this can be achieved through the command in the input script?
Thanks a lot.
Teng
