Question on pair_style dpd
Hi all,
I try to use LAMMPS pair_style dpd to reproduce the morphologies of diblock block copolymer melt obtained in Groot’s paper (Dynamic simulation of diblock copolymer microphase separation). However, with the parameters supposed to get lamellae phase, I got a disordered phase while in HOOMD-blue, I could get lamellae phase. I have attached my input files and result below. I wonder if there is anything wrong with my input scripts or if there is any issue with the dpd pair_style in LAMMPS. Particularly, I want to know when LAMMPS calculates non-bonded interactions, by default, will it exclude bonded atoms or not?
Boyuan
Part of the polymer.txt file
Diblock copolymer melt
24000 atoms
2 atom types
21600 bonds
1 bond types
0 20 xlo xhi
0 20 ylo yhi
0 20 zlo zhi
Atoms # bond
1 1 1 19.2237 8.52157 8.00038
2 1 1 19.1454 8.76061 8.41504
3 1 1 19.7577 9.10032 7.70855
4 1 1 19.8181 9.05956 7.32281
5 1 1 19.6175 9.47839 7.35945
6 1 2 19.5462 9.33713 7.40166
7 1 2 19.24 9.24531 7.68145
8 1 2 19.082 9.01368 7.59658
9 1 2 19.3272 8.73811 7.32866
10 1 2 19.7041 8.63656 7.61278
11 2 1 15.7688 16.0142 12.4761
12 2 1 15.8157 16.2 12.5508
13 2 1 15.8752 15.4791 12.9142
14 2 1 16.0583 15.3646 12.8215
15 2 1 15.7808 15.1941 12.9312
16 2 2 15.5727 15.0802 12.3917
17 2 2 15.962 15.1947 12.5356
18 2 2 15.5992 15.357 12.396
19 2 2 15.0698 15.2993 12.0094
20 2 2 14.7752 14.9839 11.9955
Bonds
1 1 1 2
2 1 2 3
3 1 3 4
4 1 4 5
5 1 5 6
6 1 6 7
7 1 7 8
8 1 8 9
9 1 9 10
10 1 11 12
11 1 12 13
12 1 13 14
13 1 14 15
14 1 15 16
15 1 16 17
16 1 17 18
17 1 18 19
18 1 19 20
19 1 21 22
20 1 22 23
polymer.in (743 Bytes)
polymer.out (2.1 KB)
Hi all,
​nobody here will do the debugging of your inputs for you.​ if you feel,
that LAMMPS is not computing interactions correctly, the burden of proof is
on you and not vice versa it is not our job to point out where you are
doing something different than from what you do with HOOMD.
​if you do not change the speacial_bonds settings, all 1-2, 1-3, and 1-4
pairs (it doesn't matter whether you have no angles or dihedrals) are
excluded from the neighbor list and thus from contributing to non-bonded​
interactions.
