Dear LAMMPS users and developers,
I have 3 questions about TAD method, regarding simulation of vacancy migration in nano-crystalline Ni in long-time scales.
I intend to simulate conventional vacancy hoping using TAD method, and I had the following questions:
1- tmax: (reciprocal of lowest expected pre-exponential factor (time units))
Is this parameter the same as V_min (temperature independent pre-exponential factor described in Voters’ paper_Sorensen and Voter, J Chem Phys, 112, 9599 (2000)) ?
and if the answer is yes; in literature of vacancy hopping, it is said that V_min should be between 1e-13 and 1e-12, so its reciprocal would be between 1e12 and 1e13. Can I put this very big value as the tmax in my code?
2- I have written my code in a way that it just looks for atomic displacement more than 2 Angstrom (which can be described in a reverse state as a vacancy diffusion);
How can I dump my system, whenever this event occurs? (I need id, and positions of each atom, when atomic displacement more than 2 A occurs)
3- it is said in LAMMPS manual that N is the number of time steps to run;
Is it the total time steps for the entire simulation?, or is it the time steps for each basin-constrained MD simulation and LAMMPS will perform the same exact number of time steps after each transition occurs?
(e.g., I want to simulate vacancy hopping for 1 ms, and with del(t)=0.001 ps, do I have to continue my simulation for 1e9 consecutive time steps? or I have misunderstood the manual…)
(+) 3- Also, in the TAD section, I have performed NEB calculations;
Can LAMMPS give me the activation barrier of the events that are desired (atomic displacement more than 2 A), simultaneously with TAD simulation?
and if the answer is yes, how can I have the migration barriers of all the desired events? (something like dumping the id, atomic positions and migration barrier of the occurred event at the same time)
I have attached my codes, including TAD counterparts. Thanks in advance for your time.
*** (The LAMMPS version which the restart files are created: 12 Mar 2015-ICMS on win 7 64-bit OS)
in02.cpu.gb (2.16 KB)
