Question regarding Class 2 Dihedral Potential Documentation
On the dihedral_style class2 page, a term for Eaa is not defined, while it is clearly present in all literature references, e.g.,
  1. http://www.sklogwiki.org/SklogWiki/index.php/COMPASS;
  2. COMPASS: An ab Initio Force-Field Optimized for Condensed-Phase Applications doi: 10.1021/jp980939v
Is this a documentation mistake, or is there a reason for this?
Fred
Hi Fred
It is included in the improper torsion term in LAMMPS. http://lammps.sandia.gov/doc/improper_class2.html
Paul
MATERIALS DESIGN, INC.
6 First National Place / PO Box 2000 | Angel Fire, New Mexico 87710 | USA
Direct +1.760.495.4924, ext. 102 | Mobile +1.505.603.8182 | Fax +1.760.897.2179
[email protected]... | www.materialsdesign.com
This email is covered by the Electronic Communications Privacy Act, 18 U.S.C. Section 2510-2521. This message and any attachments hereto may contain confidential information intended only for the use of the individual or entity named above. If you are not the intended recipient(s), or the employee or agent responsible for delivery of this message to the intended recipient(s), you are hereby notified that any dissemination, distribution or copying of this email message is strictly prohibited. If you have received this message in error, please immediately notify the sender and delete this email from your computer. The sender does not waive any privilege in the event this message was inadvertently disseminated.
MedeA® and Materials Design® are registered trademarks of Materials Design, Inc.
Never mind, I figured it out.
–Fred
