Dear ATC users,
I am trying to evaluate the virial stress/atom computed using lammps and then projected onto the mesh created by “fix_modify AtC fem mesh”. However, I am not able to output this computed quantity. The commands I am using, after minimization of the system, are the following:
fix AtC all atc hardy
fix_modify AtC transfer fields none
fix_modify AtC transfer fields add density
fix_modify AtC transfer kernel cubic_sphere 10.0
fix_modify AtC fem create mesh 9 9 9 mdRegion f f f
fix_modify AtC transfer internal type internal
compute PerAtomSt all stress/atom
fix_modify AtC transfer computes add PerAtomSt volume
fix_modify AtC transfer output ClusterFE 1 text tensor_components
fix_modify AtC transfer atomic_output ClusterMD 1 tensor_components
run 1
When I run this code, I get the following error:
ERROR: Per-atom virial was not tallied on needed timestep (compute_stress_atom.cpp:94)
My guess is that the error is due to the fact that I specify compute before the “run” command. If I specify the compute stress/atom after the run command as shown below, the output files do not contain any of the virial stress information.
run 1
Is there another output command for quantities calculated using compute and then projected onto the mesh? Any suggestions are highly appreciated.
Srikanth
