Dear developers,
I am trying to use the command - group with dynamic region and have questions.
My system has two walls in x-direction and particles between them. While moving one of walls, I want to keep track of all particles with dynamic region keyword.
I am using the version of 30Jul2016.
The result is,
(v_ngas : number of particles defined by the type, v_nbulk : number of particles defined by group - dynamic - region)
(v_locpis3 : location of moving wall - x direction, v_piston : xhi of the region which is used in group-dynamic-region)
Time-averaged data for fix record_3
TimeStep c_mdtemp v_allpress v_allpress2 v_ngas v_nbulk v_locpis3 v_piston
0 379.295 159.573 322.344 702 702 49.9991 49.999
1000 372.641 169.695 336.07 702 702 51.0011 50.999
2000 372.019 155.715 298.871 702 699 52.0011 51.999
3000 369.721 140.362 264.055 702 697 53.0011 52.999
4000 353.437 151.541 271.718 702 683 54.0011 53.999
5000 349.328 119.439 202.502 702 668 55.0011 54.999
Log file has only warning,
WARNING: One or more dynamic groups may not be updated at correct point in timestep (…/fix_group.cpp:149).
v_ngas and v_nbulk are supposed to be same if it works. I need your help.
Baek
log.lammps (8.39 KB)
press.realtime.txt (2.68 KB)
test.in (3.38 KB)
test_data.txt (136 KB)
