Hi all,
I have written a code that gets an error when I run it.
Does anybody know how I can solve it
do you mind telling usl me how you believe that this *should* work?
you *must not* mix and match cutoff and long-range coulomb. this will
result in *completely* inconsistent forces. the complaint about the
different cutoffs goes on top of that and even with no long-range
interaction, this is a bad idea.
Even if you set the a same cut-off value for both lj/cut/coul/cut &
buck/coul/long lammps gives error. You should use lj/cut/coul/long instead
of lj/cut/coul/cut when you combine it with another long-range potential
(here buck/coul/long).
