questions about in.gaussianIC_ttm
Aug 10th
Recently I studied the fix atc command.I have some questions about in.gaussianIC_ttm in examples/USER/atc/bar1d_two_temperature. For examples:
fix_modify AtC transfer initial electron_temperature all gaussian 0 0 0 1 0 0 5 20 20
fix_modify AtC transfer fix electron_temperature all gaussian 0 0 0 1 0 0 5 20 20
What is the parameters 0 0 0 1 0 0 5 20 20 means in gaussian distribution?
What is the expression of gaussian temperature distribution?
I really appreciate for your help~
Nafens
The fix atc doc page and its links should document the args
for the command - send an email to the ATC package owners
if you're stuck. A Guassian temperature distribution is
discussed briefly on the velocity doc page. Look in a stat
mech book if you need the formula.
The specific parameters are defined in user functions, the gaussian being an example. If you look in XT_Function.h/cpp, you will see how the functions parse their input parameters and are evaluated.
Jeremy
