Dear Authors of LAMMPS,
I run lammps with the airebo potential. I wonder weather the subroutines for the tricubic spline of piRC in airebo potential has some bugs.
To make things simple, I have considered the piRC sipline for an isotropically stretched graphene,in which the piRC can be reduced into piRC=F(2fc,2fc,1+8fc*fc), where fc is the cutoff function. Thus I can extract the spline subroutines of airebo from lammps source code and draw the curves of F,dFdx,dFdy and dFdz vs bond length with the parameters given in CH.airebo file.
I get curves which have some unsmooth and enven zigzag parttens at the range of bond length between 1.7 and 2.0 angstroms.
Yours sincerely
zehui
By the way, the version of lammps I use is lammps-9Nov11.
The following is the data with the columns being r, F, dFdx, dFdy, dFdz repectively. You can import it into some data-plotting software
to plot it.
1.200800 0.000000 0.000000 0.000000 0.000000
1.201600 0.000000 0.000000 0.000000 0.000000
1.202400 0.000000 0.000000 0.000000 0.000000
1.203200 0.000000 0.000000 0.000000 0.000000
1.204000 0.000000 0.000000 0.000000 0.000000
1.204800 0.000000 0.000000 0.000000 0.000000
1.205600 0.000000 0.000000 0.000000 0.000000
1.206400 0.000000 0.000000 0.000000 0.000000
1.207200 0.000000 0.000000 0.000000 0.000000
1.208000 0.000000 0.000000 0.000000 0.000000
1.208800 0.000000 0.000000 0.000000 0.000000
1.209600 0.000000 0.000000 0.000000 0.000000
1.210400 0.000000 0.000000 0.000000 0.000000
1.211200 0.000000 0.000000 0.000000 0.000000
1.212000 0.000000 0.000000 0.000000 0.000000
1.212800 0.000000 0.000000 0.000000 0.000000
1.213600 0.000000 0.000000 0.000000 0.000000
1.214400 0.000000 0.000000 0.000000 0.000000
1.215200 0.000000 0.000000 0.000000 0.000000
1.216000 0.000000 0.000000 0.000000 0.000000
1.216800 0.000000 0.000000 0.000000 0.000000
1.217600 0.000000 0.000000 0.000000 0.000000
1.218400 0.000000 0.000000 0.000000 0.000000
1.219200 0.000000 0.000000 0.000000 0.000000
1.220000 0.000000 0.000000 0.000000 0.000000
1.220800 0.000000 0.000000 0.000000 0.000000
1.221600 0.000000 0.000000 0.000000 0.000000
1.222400 0.000000 0.000000 0.000000 0.000000
1.223200 0.000000 0.000000 0.000000 0.000000
1.224000 0.000000 0.000000 0.000000 0.000000
1.224800 0.000000 0.000000 0.000000 0.000000
1.225600 0.000000 0.000000 0.000000 0.000000
1.226400 0.000000 0.000000 0.000000 0.000000
1.227200 0.000000 0.000000 0.000000 0.000000
1.228000 0.000000 0.000000 0.000000 0.000000
1.228800 0.000000 0.000000 0.000000 0.000000
1.229600 0.000000 0.000000 0.000000 0.000000
1.230400 0.000000 0.000000 0.000000 0.000000
1.231200 0.000000 0.000000 0.000000 0.000000
1.232000 0.000000 0.000000 0.000000 0.000000
1.232800 0.000000 0.000000 0.000000 0.000000
1.233600 0.000000 0.000000 0.000000 0.000000
1.234400 0.000000 0.000000 0.000000 0.000000
1.235200 0.000000 0.000000 0.000000 0.000000
1.236000 0.000000 0.000000 0.000000 0.000000
1.236800 0.000000 0.000000 0.000000 0.000000
1.237600 0.000000 0.000000 0.000000 0.000000
1.238400 0.000000 0.000000 0.000000 0.000000
1.239200 0.000000 0.000000 0.000000 0.000000
1.240000 0.000000 0.000000 0.000000 0.000000
1.240800 0.000000 0.000000 0.000000 0.000000
1.241600 0.000000 0.000000 0.000000 0.000000
1.242400 0.000000 0.000000 0.000000 0.000000
1.243200 0.000000 0.000000 0.000000 0.000000
1.244000 0.000000 0.000000 0.000000 0.000000
1.244800 0.000000 0.000000 0.000000 0.000000
1.245600 0.000000 0.000000 0.000000 0.000000
1.246400 0.000000 0.000000 0.000000 0.000000
1.247200 0.000000 0.000000 0.000000 0.000000
1.248000 0.000000 0.000000 0.000000 0.000000
1.248800 0.000000 0.000000 0.000000 0.000000
1.249600 0.000000 0.000000 0.000000 0.000000
1.250400 0.000000 0.000000 0.000000 0.000000
1.251200 0.000000 0.000000 0.000000 0.000000
1.252000 0.000000 0.000000 0.000000 0.000000
1.252800 0.000000 0.000000 0.000000 0.000000
1.253600 0.000000 0.000000 0.000000 0.000000
1.254400 0.000000 0.000000 0.000000 0.000000
1.255200 0.000000 0.000000 0.000000 0.000000
1.256000 0.000000 0.000000 0.000000 0.000000
1.256800 0.000000 0.000000 0.000000 0.000000
1.257600 0.000000 0.000000 0.000000 0.000000
1.258400 0.000000 0.000000 0.000000 0.000000
1.259200 0.000000 0.000000 0.000000 0.000000
1.260000 0.000000 0.000000 0.000000 0.000000
1.260800 0.000000 0.000000 0.000000 0.000000
1.261600 0.000000 0.000000 0.000000 0.000000
1.262400 0.000000 0.000000 0.000000 0.000000
1.263200 0.000000 0.000000 0.000000 0.000000
1.264000 0.000000 0.000000 0.000000 0.000000
1.264800 0.000000 0.000000 0.000000 0.000000
1.265600 0.000000 0.000000 0.000000 0.000000
1.266400 0.000000 0.000000 0.000000 0.000000
1.267200 0.000000 0.000000 0.000000 0.000000
1.268000 0.000000 0.000000 0.000000 0.000000
1.268800 0.000000 0.000000 0.000000 0.000000
1.269600 0.000000 0.000000 0.000000 0.000000
1.270400 0.000000 0.000000 0.000000 0.000000
1.271200 0.000000 0.000000 0.000000 0.000000
1.272000 0.000000 0.000000 0.000000 0.000000
1.272800 0.000000 0.000000 0.000000 0.000000
1.273600 0.000000 0.000000 0.000000 0.000000
1.274400 0.000000 0.000000 0.000000 0.000000
1.275200 0.000000 0.000000 0.000000 0.000000
1.276000 0.000000 0.000000 0.000000 0.000000
1.276800 0.000000 0.000000 0.000000 0.000000
1.277600 0.000000 0.000000 0.000000 0.000000
1.278400 0.000000 0.000000 0.000000 0.000000
1.279200 0.000000 0.000000 0.000000 0.000000
1.280000 0.000000 0.000000 0.000000 0.000000
1.280800 0.000000 0.000000 0.000000 0.000000
1.281600 0.000000 0.000000 0.000000 0.000000
1.282400 0.000000 0.000000 0.000000 0.000000
1.283200 0.000000 0.000000 0.000000 0.000000
1.284000 0.000000 0.000000 0.000000 0.000000
1.284800 0.000000 0.000000 0.000000 0.000000
1.285600 0.000000 0.000000 0.000000 0.000000
1.286400 0.000000 0.000000 0.000000 0.000000
1.287200 0.000000 0.000000 0.000000 0.000000
1.288000 0.000000 0.000000 0.000000 0.000000
1.288800 0.000000 0.000000 0.000000 0.000000
1.289600 0.000000 0.000000 0.000000 0.000000
1.290400 0.000000 0.000000 0.000000 0.000000
1.291200 0.000000 0.000000 0.000000 0.000000
1.292000 0.000000 0.000000 0.000000 0.000000
1.292800 0.000000 0.000000 0.000000 0.000000
1.293600 0.000000 0.000000 0.000000 0.000000
1.294400 0.000000 0.000000 0.000000 0.000000
1.295200 0.000000 0.000000 0.000000 0.000000
1.296000 0.000000 0.000000 0.000000 0.000000
1.296800 0.000000 0.000000 0.000000 0.000000
1.297600 0.000000 0.000000 0.000000 0.000000
1.298400 0.000000 0.000000 0.000000 0.000000
1.299200 0.000000 0.000000 0.000000 0.000000
1.300000 0.000000 0.000000 0.000000 0.000000
1.300800 0.000000 0.000000 0.000000 0.000000
1.301600 0.000000 0.000000 0.000000 0.000000
1.302400 0.000000 0.000000 0.000000 0.000000
1.303200 0.000000 0.000000 0.000000 0.000000
1.304000 0.000000 0.000000 0.000000 0.000000
1.304800 0.000000 0.000000 0.000000 0.000000
1.305600 0.000000 0.000000 0.000000 0.000000
1.306400 0.000000 0.000000 0.000000 0.000000
1.307200 0.000000 0.000000 0.000000 0.000000
1.308000 0.000000 0.000000 0.000000 0.000000
1.308800 0.000000 0.000000 0.000000 0.000000
1.309600 0.000000 0.000000 0.000000 0.000000
1.310400 0.000000 0.000000 0.000000 0.000000
1.311200 0.000000 0.000000 0.000000 0.000000
1.312000 0.000000 0.000000 0.000000 0.000000
1.312800 0.000000 0.000000 0.000000 0.000000
1.313600 0.000000 0.000000 0.000000 0.000000
1.314400 0.000000 0.000000 0.000000 0.000000
1.315200 0.000000 0.000000 0.000000 0.000000
1.316000 0.000000 0.000000 0.000000 0.000000
1.316800 0.000000 0.000000 0.000000 0.000000
1.317600 0.000000 0.000000 0.000000 0.000000
1.318400 0.000000 0.000000 0.000000 0.000000
1.319200 0.000000 0.000000 0.000000 0.000000
1.320000 0.000000 0.000000 0.000000 0.000000
1.320800 0.000000 0.000000 0.000000 0.000000
1.321600 0.000000 0.000000 0.000000 0.000000
1.322400 0.000000 0.000000 0.000000 0.000000
1.323200 0.000000 0.000000 0.000000 0.000000
1.324000 0.000000 0.000000 0.000000 0.000000
1.324800 0.000000 0.000000 0.000000 0.000000
1.325600 0.000000 0.000000 0.000000 0.000000
1.326400 0.000000 0.000000 0.000000 0.000000
1.327200 0.000000 0.000000 0.000000 0.000000
1.328000 0.000000 0.000000 0.000000 0.000000
1.328800 0.000000 0.000000 0.000000 0.000000
1.329600 0.000000 0.000000 0.000000 0.000000
1.330400 0.000000 0.000000 0.000000 0.000000
1.331200 0.000000 0.000000 0.000000 0.000000
1.332000 0.000000 0.000000 0.000000 0.000000
1.332800 0.000000 0.000000 0.000000 0.000000
1.333600 0.000000 0.000000 0.000000 0.000000
1.334400 0.000000 0.000000 0.000000 0.000000
1.335200 0.000000 0.000000 0.000000 0.000000
1.336000 0.000000 0.000000 0.000000 0.000000
1.336800 0.000000 0.000000 0.000000 0.000000
1.337600 0.000000 0.000000 0.000000 0.000000
1.338400 0.000000 0.000000 0.000000 0.000000
1.339200 0.000000 0.000000 0.000000 0.000000
1.340000 0.000000 0.000000 0.000000 0.000000
1.340800 0.000000 0.000000 0.000000 0.000000
1.341600 0.000000 0.000000 0.000000 0.000000
1.342400 0.000000 0.000000 0.000000 0.000000
1.343200 0.000000 0.000000 0.000000 0.000000
1.344000 0.000000 0.000000 0.000000 0.000000
1.344800 0.000000 0.000000 0.000000 0.000000
1.345600 0.000000 0.000000 0.000000 0.000000
1.346400 0.000000 0.000000 0.000000 0.000000
1.347200 0.000000 0.000000 0.000000 0.000000
1.348000 0.000000 0.000000 0.000000 0.000000
1.348800 0.000000 0.000000 0.000000 0.000000
1.349600 0.000000 0.000000 0.000000 0.000000
1.350400 0.000000 0.000000 0.000000 0.000000
1.351200 0.000000 0.000000 0.000000 0.000000
1.352000 0.000000 0.000000 0.000000 0.000000
1.352800 0.000000 0.000000 0.000000 0.000000
1.353600 0.000000 0.000000 0.000000 0.000000
1.354400 0.000000 0.000000 0.000000 0.000000
1.355200 0.000000 0.000000 0.000000 0.000000
1.356000 0.000000 0.000000 0.000000 0.000000
1.356800 0.000000 0.000000 0.000000 0.000000
1.357600 0.000000 0.000000 0.000000 0.000000
1.358400 0.000000 0.000000 0.000000 0.000000
1.359200 0.000000 0.000000 0.000000 0.000000
1.360000 0.000000 0.000000 0.000000 0.000000
1.360800 0.000000 0.000000 0.000000 0.000000
1.361600 0.000000 0.000000 0.000000 0.000000
1.362400 0.000000 0.000000 0.000000 0.000000
1.363200 0.000000 0.000000 0.000000 0.000000
1.364000 0.000000 0.000000 0.000000 0.000000
1.364800 0.000000 0.000000 0.000000 0.000000
1.365600 0.000000 0.000000 0.000000 0.000000
1.366400 0.000000 0.000000 0.000000 0.000000
1.367200 0.000000 0.000000 0.000000 0.000000
1.368000 0.000000 0.000000 0.000000 0.000000
1.368800 0.000000 0.000000 0.000000 0.000000
1.369600 0.000000 0.000000 0.000000 0.000000
1.370400 0.000000 0.000000 0.000000 0.000000
1.371200 0.000000 0.000000 0.000000 0.000000
1.372000 0.000000 0.000000 0.000000 0.000000
1.372800 0.000000 0.000000 0.000000 0.000000
1.373600 0.000000 0.000000 0.000000 0.000000
1.374400 0.000000 0.000000 0.000000 0.000000
1.375200 0.000000 0.000000 0.000000 0.000000
1.376000 0.000000 0.000000 0.000000 0.000000
1.376800 0.000000 0.000000 0.000000 0.000000
1.377600 0.000000 0.000000 0.000000 0.000000
1.378400 0.000000 0.000000 0.000000 0.000000
1.379200 0.000000 0.000000 0.000000 0.000000
1.380000 0.000000 0.000000 0.000000 0.000000
1.380800 0.000000 0.000000 0.000000 0.000000
1.381600 0.000000 0.000000 0.000000 0.000000
1.382400 0.000000 0.000000 0.000000 0.000000
1.383200 0.000000 0.000000 0.000000 0.000000
1.384000 0.000000 0.000000 0.000000 0.000000
1.384800 0.000000 0.000000 0.000000 0.000000
1.385600 0.000000 0.000000 0.000000 0.000000
1.386400 0.000000 0.000000 0.000000 0.000000
1.387200 0.000000 0.000000 0.000000 0.000000
1.388000 0.000000 0.000000 0.000000 0.000000
1.388800 0.000000 0.000000 0.000000 0.000000
1.389600 0.000000 0.000000 0.000000 0.000000
1.390400 0.000000 0.000000 0.000000 0.000000
1.391200 0.000000 0.000000 0.000000 0.000000
1.392000 0.000000 0.000000 0.000000 0.000000
1.392800 0.000000 0.000000 0.000000 0.000000
1.393600 0.000000 0.000000 0.000000 0.000000
1.394400 0.000000 0.000000 0.000000 0.000000
1.395200 0.000000 0.000000 0.000000 0.000000
1.396000 0.000000 0.000000 0.000000 0.000000
1.396800 0.000000 0.000000 0.000000 0.000000
1.397600 0.000000 0.000000 0.000000 0.000000
1.398400 0.000000 0.000000 0.000000 0.000000
1.399200 0.000000 0.000000 0.000000 0.000000
1.400000 0.000000 0.000000 0.000000 0.000000
1.400800 0.000000 0.000000 0.000000 0.000000
1.401600 0.000000 0.000000 0.000000 0.000000
1.402400 0.000000 0.000000 0.000000 0.000000
1.403200 0.000000 0.000000 0.000000 0.000000
1.404000 0.000000 0.000000 0.000000 0.000000
1.404800 0.000000 0.000000 0.000000 0.000000
1.405600 0.000000 0.000000 0.000000 0.000000
1.406400 0.000000 0.000000 0.000000 0.000000
1.407200 0.000000 0.000000 0.000000 0.000000
1.408000 0.000000 0.000000 0.000000 0.000000
1.408800 0.000000 0.000000 0.000000 0.000000
1.409600 0.000000 0.000000 0.000000 0.000000
1.410400 0.000000 0.000000 0.000000 0.000000
1.411200 0.000000 0.000000 0.000000 0.000000
1.412000 0.000000 0.000000 0.000000 0.000000
1.412800 0.000000 0.000000 0.000000 0.000000
1.413600 0.000000 0.000000 0.000000 0.000000
1.414400 0.000000 0.000000 0.000000 0.000000
1.415200 0.000000 0.000000 0.000000 0.000000
1.416000 0.000000 0.000000 0.000000 0.000000
1.416800 0.000000 0.000000 0.000000 0.000000
1.417600 0.000000 0.000000 0.000000 0.000000
1.418400 0.000000 0.000000 0.000000 0.000000
1.419200 0.000000 0.000000 0.000000 0.000000
1.420000 0.000000 0.000000 0.000000 0.000000
1.420800 0.000000 0.000000 0.000000 0.000000
1.421600 0.000000 0.000000 0.000000 0.000000
1.422400 0.000000 0.000000 0.000000 0.000000
1.423200 0.000000 0.000000 0.000000 0.000000
1.424000 0.000000 0.000000 0.000000 0.000000
1.424800 0.000000 0.000000 0.000000 0.000000
1.425600 0.000000 0.000000 0.000000 0.000000
1.426400 0.000000 0.000000 0.000000 0.000000
1.427200 0.000000 0.000000 0.000000 0.000000
1.428000 0.000000 0.000000 0.000000 0.000000
1.428800 0.000000 0.000000 0.000000 0.000000
1.429600 0.000000 0.000000 0.000000 0.000000
1.430400 0.000000 0.000000 0.000000 0.000000
1.431200 0.000000 0.000000 0.000000 0.000000
1.432000 0.000000 0.000000 0.000000 0.000000
1.432800 0.000000 0.000000 0.000000 0.000000
1.433600 0.000000 0.000000 0.000000 0.000000
1.434400 0.000000 0.000000 0.000000 0.000000
1.435200 0.000000 0.000000 0.000000 0.000000
1.436000 0.000000 0.000000 0.000000 0.000000
1.436800 0.000000 0.000000 0.000000 0.000000
1.437600 0.000000 0.000000 0.000000 0.000000
1.438400 0.000000 0.000000 0.000000 0.000000
1.439200 0.000000 0.000000 0.000000 0.000000
1.440000 0.000000 0.000000 0.000000 0.000000
1.440800 0.000000 0.000000 0.000000 0.000000
1.441600 0.000000 0.000000 0.000000 0.000000
1.442400 0.000000 0.000000 0.000000 0.000000
1.443200 0.000000 0.000000 0.000000 0.000000
1.444000 0.000000 0.000000 0.000000 0.000000
1.444800 0.000000 0.000000 0.000000 0.000000
1.445600 0.000000 0.000000 0.000000 0.000000
1.446400 0.000000 0.000000 0.000000 0.000000
1.447200 0.000000 0.000000 0.000000 0.000000
1.448000 0.000000 0.000000 0.000000 0.000000
1.448800 0.000000 0.000000 0.000000 0.000000
1.449600 0.000000 0.000000 0.000000 0.000000
1.450400 0.000000 0.000000 0.000000 0.000000
1.451200 0.000000 0.000000 0.000000 0.000000
1.452000 0.000000 0.000000 0.000000 0.000000
1.452800 0.000000 0.000000 0.000000 0.000000
1.453600 0.000000 0.000000 0.000000 0.000000
1.454400 0.000000 0.000000 0.000000 0.000000
1.455200 0.000000 0.000000 0.000000 0.000000
1.456000 0.000000 0.000000 0.000000 0.000000
1.456800 0.000000 0.000000 0.000000 0.000000
1.457600 0.000000 0.000000 0.000000 0.000000
1.458400 0.000000 0.000000 0.000000 0.000000
1.459200 0.000000 0.000000 0.000000 0.000000
1.460000 0.000000 0.000000 0.000000 0.000000
1.460800 0.000000 0.000000 0.000000 0.000000
1.461600 0.000000 0.000000 0.000000 0.000000
1.462400 0.000000 0.000000 0.000000 0.000000
1.463200 0.000000 0.000000 0.000000 0.000000
1.464000 0.000000 0.000000 0.000000 0.000000
1.464800 0.000000 0.000000 0.000000 0.000000
1.465600 0.000000 0.000000 0.000000 0.000000
1.466400 0.000000 0.000000 0.000000 0.000000
1.467200 0.000000 0.000000 0.000000 0.000000
1.468000 0.000000 0.000000 0.000000 0.000000
1.468800 0.000000 0.000000 0.000000 0.000000
1.469600 0.000000 0.000000 0.000000 0.000000
1.470400 0.000000 0.000000 0.000000 0.000000
1.471200 0.000000 0.000000 0.000000 0.000000
1.472000 0.000000 0.000000 0.000000 0.000000
1.472800 0.000000 0.000000 0.000000 0.000000
1.473600 0.000000 0.000000 0.000000 0.000000
1.474400 0.000000 0.000000 0.000000 0.000000
1.475200 0.000000 0.000000 0.000000 0.000000
1.476000 0.000000 0.000000 0.000000 0.000000
1.476800 0.000000 0.000000 0.000000 0.000000
1.477600 0.000000 0.000000 0.000000 0.000000
1.478400 0.000000 0.000000 0.000000 0.000000
1.479200 0.000000 0.000000 0.000000 0.000000
1.480000 0.000000 0.000000 0.000000 0.000000
1.480800 0.000000 0.000000 0.000000 0.000000
1.481600 0.000000 0.000000 0.000000 0.000000
1.482400 0.000000 0.000000 0.000000 0.000000
1.483200 0.000000 0.000000 0.000000 0.000000
1.484000 0.000000 0.000000 0.000000 0.000000
1.484800 0.000000 0.000000 0.000000 0.000000
1.485600 0.000000 0.000000 0.000000 0.000000
1.486400 0.000000 0.000000 0.000000 0.000000
1.487200 0.000000 0.000000 0.000000 0.000000
1.488000 0.000000 0.000000 0.000000 0.000000
1.488800 0.000000 0.000000 0.000000 0.000000
1.489600 0.000000 0.000000 0.000000 0.000000
1.490400 0.000000 0.000000 0.000000 0.000000
1.491200 0.000000 0.000000 0.000000 0.000000
1.492000 0.000000 0.000000 0.000000 0.000000
1.492800 0.000000 0.000000 0.000000 0.000000
1.493600 0.000000 0.000000 0.000000 0.000000
1.494400 0.000000 0.000000 0.000000 0.000000
1.495200 0.000000 0.000000 0.000000 0.000000
1.496000 0.000000 0.000000 0.000000 0.000000
1.496800 0.000000 0.000000 0.000000 0.000000
1.497600 0.000000 0.000000 0.000000 0.000000
1.498400 0.000000 0.000000 0.000000 0.000000
1.499200 0.000000 0.000000 0.000000 0.000000
1.500000 0.000000 0.000000 0.000000 0.000000
1.500800 0.000000 0.000000 0.000000 0.000000
1.501600 0.000000 0.000000 0.000000 0.000000
1.502400 0.000000 0.000000 0.000000 0.000000
1.503200 0.000000 0.000000 0.000000 0.000000
1.504000 0.000000 0.000000 0.000000 0.000000
1.504800 0.000000 0.000000 0.000000 0.000000
1.505600 0.000000 0.000000 0.000000 0.000000
1.506400 0.000000 0.000000 0.000000 0.000000
1.507200 0.000000 0.000000 0.000000 0.000000
1.508000 0.000000 0.000000 0.000000 0.000000
1.508800 0.000000 0.000000 0.000000 0.000000
1.509600 0.000000 0.000000 0.000000 0.000000
1.510400 0.000000 0.000000 0.000000 0.000000
1.511200 0.000000 0.000000 0.000000 0.000000
1.512000 0.000000 0.000000 0.000000 0.000000
1.512800 0.000000 0.000000 0.000000 0.000000
1.513600 0.000000 0.000000 0.000000 0.000000
1.514400 0.000000 0.000000 0.000000 0.000000
1.515200 0.000000 0.000000 0.000000 0.000000
1.516000 0.000000 0.000000 0.000000 0.000000
1.516800 0.000000 0.000000 0.000000 0.000000
1.517600 0.000000 0.000000 0.000000 0.000000
1.518400 0.000000 0.000000 0.000000 0.000000
1.519200 0.000000 0.000000 0.000000 0.000000
1.520000 0.000000 0.000000 0.000000 0.000000
1.520800 0.000000 0.000000 0.000000 0.000000
1.521600 0.000000 0.000000 0.000000 0.000000
1.522400 0.000000 0.000000 0.000000 0.000000
1.523200 0.000000 0.000000 0.000000 0.000000
1.524000 0.000000 0.000000 0.000000 0.000000
1.524800 0.000000 0.000000 0.000000 0.000000
1.525600 0.000000 0.000000 0.000000 0.000000
1.526400 0.000000 0.000000 0.000000 0.000000
1.527200 0.000000 0.000000 0.000000 0.000000
1.528000 0.000000 0.000000 0.000000 0.000000
1.528800 0.000000 0.000000 0.000000 0.000000
1.529600 0.000000 0.000000 0.000000 0.000000
1.530400 0.000000 0.000000 0.000000 0.000000
1.531200 0.000000 0.000000 0.000000 0.000000
1.532000 0.000000 0.000000 0.000000 0.000000
1.532800 0.000000 0.000000 0.000000 0.000000
1.533600 0.000000 0.000000 0.000000 0.000000
1.534400 0.000000 0.000000 0.000000 0.000000
1.535200 0.000000 0.000000 0.000000 0.000000
1.536000 0.000000 0.000000 0.000000 0.000000
1.536800 0.000000 0.000000 0.000000 0.000000
1.537600 0.000000 0.000000 0.000000 0.000000
1.538400 0.000000 0.000000 0.000000 0.000000
1.539200 0.000000 0.000000 0.000000 0.000000
1.540000 0.000000 0.000000 0.000000 0.000000
1.540800 0.000000 0.000000 0.000000 0.000000
1.541600 0.000000 0.000000 0.000000 0.000000
1.542400 0.000000 0.000000 0.000000 0.000000
1.543200 0.000000 0.000000 0.000000 0.000000
1.544000 0.000000 0.000000 0.000000 0.000000
1.544800 0.000000 0.000000 0.000000 0.000000
1.545600 0.000000 0.000000 0.000000 0.000000
1.546400 0.000000 0.000000 0.000000 0.000000
1.547200 0.000000 0.000000 0.000000 0.000000
1.548000 0.000000 0.000000 0.000000 0.000000
1.548800 0.000000 0.000000 0.000000 0.000000
1.549600 0.000000 0.000000 0.000000 0.000000
1.550400 0.000000 0.000000 0.000000 0.000000
1.551200 0.000000 0.000000 0.000000 0.000000
1.552000 0.000000 0.000000 0.000000 0.000000
1.552800 0.000000 0.000000 0.000000 0.000000
1.553600 0.000000 0.000000 0.000000 0.000000
1.554400 0.000000 0.000000 0.000000 0.000000
1.555200 0.000000 0.000000 0.000000 0.000000
1.556000 0.000000 0.000000 0.000000 0.000000
1.556800 0.000000 0.000000 0.000000 0.000000
1.557600 0.000000 0.000000 0.000000 0.000000
1.558400 0.000000 0.000000 0.000000 0.000000
1.559200 0.000000 0.000000 0.000000 0.000000
1.560000 0.000000 0.000000 0.000000 0.000000
1.560800 0.000000 0.000000 0.000000 0.000000
1.561600 0.000000 0.000000 0.000000 0.000000
1.562400 0.000000 0.000000 0.000000 0.000000
1.563200 0.000000 0.000000 0.000000 0.000000
1.564000 0.000000 0.000000 0.000000 0.000000
1.564800 0.000000 0.000000 0.000000 0.000000
1.565600 0.000000 0.000000 0.000000 0.000000
1.566400 0.000000 0.000000 0.000000 0.000000
1.567200 0.000000 0.000000 0.000000 0.000000
1.568000 0.000000 0.000000 0.000000 0.000000
1.568800 0.000000 0.000000 0.000000 0.000000
1.569600 0.000000 0.000000 0.000000 0.000000
1.570400 0.000000 0.000000 0.000000 0.000000
1.571200 0.000000 0.000000 0.000000 0.000000
1.572000 0.000000 0.000000 0.000000 0.000000
1.572800 0.000000 0.000000 0.000000 0.000000
1.573600 0.000000 0.000000 0.000000 0.000000
1.574400 0.000000 0.000000 0.000000 0.000000
1.575200 0.000000 0.000000 0.000000 0.000000
1.576000 0.000000 0.000000 0.000000 0.000000
1.576800 0.000000 0.000000 0.000000 0.000000
1.577600 0.000000 0.000000 0.000000 0.000000
1.578400 0.000000 0.000000 0.000000 0.000000
1.579200 0.000000 0.000000 0.000000 0.000000
1.580000 0.000000 0.000000 0.000000 0.000000
1.580800 0.000000 0.000000 0.000000 0.000000
1.581600 0.000000 0.000000 0.000000 0.000000
1.582400 0.000000 0.000000 0.000000 0.000000
1.583200 0.000000 0.000000 0.000000 0.000000
1.584000 0.000000 0.000000 0.000000 0.000000
1.584800 0.000000 0.000000 0.000000 0.000000
1.585600 0.000000 0.000000 0.000000 0.000000
1.586400 0.000000 0.000000 0.000000 0.000000
1.587200 0.000000 0.000000 0.000000 0.000000
1.588000 0.000000 0.000000 0.000000 0.000000
1.588800 0.000000 0.000000 0.000000 0.000000
1.589600 0.000000 0.000000 0.000000 0.000000
1.590400 0.000000 0.000000 0.000000 0.000000
1.591200 0.000000 0.000000 0.000000 0.000000
1.592000 0.000000 0.000000 0.000000 0.000000
1.592800 0.000000 0.000000 0.000000 0.000000
1.593600 0.000000 0.000000 0.000000 0.000000
1.594400 0.000000 0.000000 0.000000 0.000000
1.595200 0.000000 0.000000 0.000000 0.000000
1.596000 0.000000 0.000000 0.000000 0.000000
1.596800 0.000000 0.000000 0.000000 0.000000
1.597600 0.000000 0.000000 0.000000 0.000000
1.598400 0.000000 0.000000 0.000000 0.000000
1.599200 0.000000 0.000000 0.000000 0.000000
1.600000 0.000000 0.000000 0.000000 0.000000
1.600800 0.000000 0.000000 0.000000 0.000000
1.601600 0.000000 0.000000 0.000000 0.000000
1.602400 0.000000 0.000000 0.000000 0.000000
1.603200 0.000000 0.000000 0.000000 0.000000
1.604000 0.000000 0.000000 0.000000 0.000000
1.604800 0.000000 0.000000 0.000000 0.000000
1.605600 0.000000 0.000000 0.000000 0.000000
1.606400 0.000000 0.000000 0.000000 0.000000
1.607200 0.000000 0.000000 0.000000 0.000000
1.608000 0.000000 0.000000 0.000000 0.000000
1.608800 0.000000 0.000000 0.000000 0.000000
1.609600 0.000000 0.000000 0.000000 0.000000
1.610400 0.000000 0.000000 0.000000 0.000000
1.611200 0.000000 0.000000 0.000000 0.000000
1.612000 0.000000 0.000000 0.000000 0.000000
1.612800 0.000000 0.000000 0.000000 0.000000
1.613600 0.000000 0.000000 0.000000 0.000000
1.614400 0.000000 0.000000 0.000000 0.000000
1.615200 0.000000 0.000000 0.000000 0.000000
1.616000 0.000000 0.000000 0.000000 0.000000
1.616800 0.000000 0.000000 0.000000 0.000000
1.617600 0.000000 0.000000 0.000000 0.000000
1.618400 0.000000 0.000000 0.000000 0.000000
1.619200 0.000000 0.000000 0.000000 0.000000
1.620000 0.000000 0.000000 0.000000 0.000000
1.620800 0.000000 0.000000 0.000000 0.000000
1.621600 0.000000 0.000000 0.000000 0.000000
1.622400 0.000000 0.000000 0.000000 0.000000
1.623200 0.000000 0.000000 0.000000 0.000000
1.624000 0.000000 0.000000 0.000000 0.000000
1.624800 0.000000 0.000000 0.000000 0.000000
1.625600 0.000000 0.000000 0.000000 0.000000
1.626400 0.000000 0.000000 0.000000 0.000000
1.627200 0.000000 0.000000 0.000000 0.000000
1.628000 0.000000 0.000000 0.000000 0.000000
1.628800 0.000000 0.000000 0.000000 0.000000
1.629600 0.000000 0.000000 0.000000 0.000000
1.630400 0.000000 0.000000 0.000000 0.000000
1.631200 0.000000 0.000000 0.000000 0.000000
1.632000 0.000000 0.000000 0.000000 0.000000
1.632800 0.000000 0.000000 0.000000 0.000000
1.633600 0.000000 0.000000 0.000000 0.000000
1.634400 0.000000 0.000000 0.000000 0.000000
1.635200 0.000000 0.000000 0.000000 0.000000
1.636000 0.000000 0.000000 0.000000 0.000000
1.636800 0.000000 0.000000 0.000000 0.000000
1.637600 0.000000 0.000000 0.000000 0.000000
1.638400 0.000000 0.000000 0.000000 0.000000
1.639200 0.000000 0.000000 0.000000 0.000000
1.640000 0.000000 0.000000 0.000000 0.000000
1.640800 0.000000 0.000000 0.000000 0.000000
1.641600 0.000000 0.000000 0.000000 0.000000
1.642400 0.000000 0.000000 0.000000 0.000000
1.643200 0.000000 0.000000 0.000000 0.000000
1.644000 0.000000 0.000000 0.000000 0.000000
1.644800 0.000000 0.000000 0.000000 0.000000
1.645600 0.000000 0.000000 0.000000 0.000000
1.646400 0.000000 0.000000 0.000000 0.000000
1.647200 0.000000 0.000000 0.000000 0.000000
1.648000 0.000000 0.000000 0.000000 0.000000
1.648800 0.000000 0.000000 0.000000 0.000000
1.649600 0.000000 0.000000 0.000000 0.000000
1.650400 0.000000 0.000000 0.000000 0.000000
1.651200 0.000000 0.000000 0.000000 0.000000
1.652000 0.000000 0.000000 0.000000 0.000000
1.652800 0.000000 0.000000 0.000000 0.000000
1.653600 0.000000 0.000000 0.000000 0.000000
1.654400 0.000000 0.000000 0.000000 0.000000
1.655200 0.000000 0.000000 0.000000 0.000000
1.656000 0.000000 0.000000 0.000000 0.000000
1.656800 0.000000 0.000000 0.000000 0.000000
1.657600 0.000000 0.000000 0.000000 0.000000
1.658400 0.000000 0.000000 0.000000 0.000000
1.659200 0.000000 0.000000 0.000000 0.000000
1.660000 0.000000 0.000000 0.000000 0.000000
1.660800 0.000000 0.000000 0.000000 0.000000
1.661600 0.000000 0.000000 0.000000 0.000000
1.662400 0.000000 0.000000 0.000000 0.000000
1.663200 0.000000 0.000000 0.000000 0.000000
1.664000 0.000000 0.000000 0.000000 0.000000
1.664800 0.000000 0.000000 0.000000 0.000000
1.665600 0.000000 0.000000 0.000000 0.000000
1.666400 0.000000 0.000000 0.000000 0.000000
1.667200 0.000000 0.000000 0.000000 0.000000
1.668000 0.000000 0.000000 0.000000 0.000000
1.668800 0.000000 0.000000 0.000000 0.000000
1.669600 0.000000 0.000000 0.000000 0.000000
1.670400 0.000000 0.000000 0.000000 0.000000
1.671200 0.000000 0.000000 0.000000 0.000000
1.672000 0.000000 0.000000 0.000000 0.000000
1.672800 0.000000 0.000000 0.000000 0.000000
1.673600 0.000000 0.000000 0.000000 0.000000
1.674400 0.000000 0.000000 0.000000 0.000000
1.675200 0.000000 0.000000 0.000000 0.000000
1.676000 0.000000 0.000000 0.000000 0.000000
1.676800 0.000000 0.000000 0.000000 0.000000
1.677600 0.000000 0.000000 0.000000 0.000000
1.678400 0.000000 0.000000 0.000000 0.000000
1.679200 0.000000 0.000000 0.000000 0.000000
1.680000 0.000000 0.000000 0.000000 0.000000
1.680800 0.000000 0.000000 0.000000 0.000000
1.681600 0.000000 0.000000 0.000000 0.000000
1.682400 0.000000 0.000000 0.000000 0.000000
1.683200 0.000000 0.000000 0.000000 0.000000
1.684000 0.000000 0.000000 0.000000 0.000000
1.684800 0.000000 0.000000 0.000000 0.000000
1.685600 0.000000 0.000000 0.000000 0.000000
1.686400 0.000000 0.000000 0.000000 0.000000
1.687200 0.000000 0.000000 0.000000 0.000000
1.688000 0.000000 0.000000 0.000000 0.000000
1.688800 0.000000 0.000000 0.000000 0.000000
1.689600 0.000000 0.000000 0.000000 0.000000
1.690400 0.000000 0.000000 0.000000 0.000000
1.691200 0.000000 0.000000 0.000000 0.000000
1.692000 0.000000 0.000000 0.000000 0.000000
1.692800 0.000000 0.000000 0.000000 0.000000
1.693600 0.000000 0.000000 0.000000 0.000000
1.694400 0.000000 0.000000 0.000000 0.000000
1.695200 0.000000 0.000000 0.000000 0.000000
1.696000 0.000000 0.000000 0.000000 0.000000
1.696800 0.000000 0.000000 0.000000 0.000000
1.697600 0.000000 0.000000 0.000000 0.000000
1.698400 0.000000 0.000000 0.000000 0.000000
1.699200 0.000000 0.000000 0.000000 0.000000
1.700000 0.000000 0.000000 0.000000 0.000000
1.700800 0.000000 0.000003 0.000003 -0.000004
1.701600 0.000000 0.000013 0.000013 -0.000015
1.702400 0.000000 0.000029 0.000029 -0.000033
1.703200 0.000000 0.000051 0.000051 -0.000059
1.704000 0.000000 0.000079 0.000079 -0.000092
1.704800 0.000001 0.000114 0.000114 -0.000133
1.705600 0.000001 0.000154 0.000154 -0.000180
1.706400 0.000002 0.000201 0.000201 -0.000234
1.707200 0.000003 0.000254 0.000254 -0.000295
1.708000 0.000004 0.000313 0.000313 -0.000363
1.708800 0.000006 0.000378 0.000378 -0.000437
1.709600 0.000008 0.000448 0.000448 -0.000518
1.710400 0.000011 0.000524 0.000524 -0.000604
1.711200 0.000015 0.000606 0.000606 -0.000696
1.712000 0.000020 0.000693 0.000693 -0.000794
1.712800 0.000026 0.000786 0.000786 -0.000896
1.713600 0.000032 0.000884 0.000884 -0.001004
1.714400 0.000040 0.000987 0.000987 -0.001116
1.715200 0.000050 0.001095 0.001095 -0.001232
1.716000 0.000061 0.001208 0.001208 -0.001352
1.716800 0.000073 0.001326 0.001326 -0.001476
1.717600 0.000087 0.001448 0.001448 -0.001602
1.718400 0.000103 0.001576 0.001576 -0.001731
1.719200 0.000121 0.001707 0.001707 -0.001863
1.720000 0.000141 0.001844 0.001844 -0.001995
1.720800 0.000163 0.001984 0.001984 -0.002129
1.721600 0.000188 0.002129 0.002129 -0.002264
1.722400 0.000215 0.002278 0.002278 -0.002399
1.723200 0.000244 0.002432 0.002432 -0.002534
1.724000 0.000276 0.002589 0.002589 -0.002668
1.724800 0.000310 0.002751 0.002751 -0.002800
1.725600 0.000347 0.002916 0.002916 -0.002930
1.726400 0.000386 0.003086 0.003086 -0.003058
1.727200 0.000428 0.003259 0.003259 -0.003182
1.728000 0.000473 0.003437 0.003437 -0.003303
1.728800 0.000520 0.003618 0.003618 -0.003419
1.729600 0.000570 0.003803 0.003803 -0.003530
1.730400 0.000622 0.003992 0.003992 -0.003636
1.731200 0.000677 0.004185 0.004185 -0.003735
1.732000 0.000733 0.004381 0.004381 -0.003827
1.732800 0.000792 0.004581 0.004581 -0.003912
1.733600 0.000853 0.004785 0.004785 -0.003988
1.734400 0.000916 0.004992 0.004992 -0.004055
1.735200 0.000980 0.005202 0.005202 -0.004113
1.736000 0.001045 0.005416 0.005416 -0.004161
1.736800 0.001111 0.005633 0.005633 -0.004198
1.737600 0.001177 0.005854 0.005854 -0.004224
1.738400 0.001244 0.006077 0.006077 -0.004237
1.739200 0.001311 0.006302 0.006302 -0.004238
1.740000 0.001377 0.006530 0.006530 -0.004226
1.740800 0.001442 0.006761 0.006761 -0.004200
1.741600 0.001506 0.006993 0.006993 -0.004160
1.742400 0.001568 0.007226 0.007226 -0.004105
1.743200 0.001627 0.007461 0.007461 -0.004035
1.744000 0.001683 0.007695 0.007695 -0.003949
1.744800 0.001735 0.007930 0.007930 -0.003847
1.745600 0.001783 0.008165 0.008165 -0.003729
1.746400 0.001826 0.008398 0.008398 -0.003593
1.747200 0.001863 0.008628 0.008628 -0.003440
1.748000 0.001894 0.008857 0.008857 -0.003270
1.748800 0.001918 0.009081 0.009081 -0.003082
1.749600 0.001935 0.009302 0.009302 -0.003001
1.750400 0.001950 0.009521 0.009521 -0.002983
1.751200 0.001962 0.009739 0.009739 -0.002964
1.752000 0.001972 0.009956 0.009956 -0.002944
1.752800 0.001979 0.010171 0.010171 -0.002924
1.753600 0.001984 0.010384 0.010384 -0.002903
1.754400 0.001985 0.010595 0.010595 -0.002881
1.755200 0.001984 0.010805 0.010805 -0.002858
1.756000 0.001980 0.011011 0.011011 -0.002835
1.756800 0.001972 0.011215 0.011215 -0.002811
1.757600 0.001962 0.011416 0.011416 -0.002786
1.758400 0.001948 0.011615 0.011615 -0.002760
1.759200 0.001932 0.011810 0.011810 -0.002734
1.760000 0.001912 0.012001 0.012001 -0.002707
1.760800 0.001888 0.012189 0.012189 -0.002679
1.761600 0.001861 0.012373 0.012373 -0.002651
1.762400 0.001831 0.012553 0.012553 -0.002622
1.763200 0.001797 0.012729 0.012729 -0.002592
1.764000 0.001760 0.012900 0.012900 -0.002562
1.764800 0.001719 0.013067 0.013067 -0.002530
1.765600 0.001674 0.013228 0.013228 -0.002499
1.766400 0.001626 0.013385 0.013385 -0.002466
1.767200 0.001574 0.013536 0.013536 -0.002433
1.768000 0.001518 0.013682 0.013682 -0.002399
1.768800 0.001459 0.013822 0.013822 -0.002365
1.769600 0.001396 0.013955 0.013955 -0.002330
1.770400 0.001329 0.014083 0.014083 -0.002295
1.771200 0.001259 0.014204 0.014204 -0.002259
1.772000 0.001184 0.014319 0.014319 -0.002222
1.772800 0.001107 0.014427 0.014427 -0.002185
1.773600 0.001025 0.014527 0.014527 -0.002147
1.774400 0.000940 0.014621 0.014621 -0.002109
1.775200 0.000851 0.014707 0.014707 -0.002071
1.776000 0.000758 0.014786 0.014786 -0.002032
1.776800 0.000662 0.014856 0.014856 -0.001992
1.777600 0.000562 0.014919 0.014919 -0.001953
1.778400 0.000459 0.014974 0.014974 -0.001913
1.779200 0.000353 0.015020 0.015020 -0.001872
1.780000 0.000243 0.015058 0.015058 -0.001832
1.780800 0.000130 0.015087 0.015087 -0.001791
1.781600 0.000014 0.015108 0.015108 -0.001750
1.782400 -0.000105 0.015120 0.015120 -0.001709
1.783200 -0.000227 0.015122 0.015122 -0.001667
1.784000 -0.000352 0.015116 0.015116 -0.001626
1.784800 -0.000480 0.015100 0.015100 -0.001584
1.785600 -0.000610 0.015075 0.015075 -0.001543
1.786400 -0.000743 0.015041 0.015041 -0.001501
1.787200 -0.000879 0.014997 0.014997 -0.001459
1.788000 -0.001016 0.014944 0.014944 -0.001418
1.788800 -0.001156 0.014881 0.014881 -0.001377
1.789600 -0.001298 0.014809 0.014809 -0.001335
1.790400 -0.001441 0.014727 0.014727 -0.001294
1.791200 -0.001588 0.014636 0.014636 -0.001152
1.792000 -0.001743 0.014540 0.014540 -0.000943
1.792800 -0.001906 0.014438 0.014438 -0.000766
1.793600 -0.002076 0.014327 0.014327 -0.000624
1.794400 -0.002250 0.014206 0.014206 -0.000518
1.795200 -0.002428 0.014073 0.014073 -0.000448
1.796000 -0.002607 0.013928 0.013928 -0.000417
1.796800 -0.002785 0.013770 0.013770 -0.000424
1.797600 -0.002961 0.013599 0.013599 -0.000469
1.798400 -0.003132 0.013417 0.013417 -0.000554
1.799200 -0.003298 0.013223 0.013223 -0.000678
1.800000 -0.003455 0.013019 0.013019 -0.000841
1.800800 -0.003601 0.012806 0.012806 -0.001042
1.801600 -0.003737 0.012589 0.012589 -0.001281
1.802400 -0.003858 0.012368 0.012368 -0.001557
1.803200 -0.003965 0.012148 0.012148 -0.001867
1.804000 -0.004055 0.011932 0.011932 -0.002212
1.804800 -0.004126 0.011724 0.011724 -0.002589
1.805600 -0.004179 0.011528 0.011528 -0.002995
1.806400 -0.004211 0.011350 0.011350 -0.003430
1.807200 -0.004223 0.011194 0.011194 -0.003890
1.808000 -0.004213 0.011066 0.011066 -0.004373
1.808800 -0.004180 0.010970 0.010970 -0.004876
1.809600 -0.004138 0.010905 0.010905 -0.004220
1.810400 -0.004161 0.010814 0.010814 -0.002434
1.811200 -0.004257 0.010676 0.010676 -0.000847
1.812000 -0.004414 0.010484 0.010484 0.000544
1.812800 -0.004624 0.010230 0.010230 0.001739
1.813600 -0.004877 0.009911 0.009911 0.002743
1.814400 -0.005163 0.009526 0.009526 0.003560
1.815200 -0.005474 0.009075 0.009075 0.004196
1.816000 -0.005801 0.008562 0.008562 0.004659
1.816800 -0.006135 0.007993 0.007993 0.004955
1.817600 -0.006469 0.007374 0.007374 0.005095
1.818400 -0.006795 0.006715 0.006715 0.005087
1.819200 -0.007107 0.006027 0.006027 0.004944
1.820000 -0.007399 0.005321 0.005321 0.004675
1.820800 -0.007665 0.004612 0.004612 0.004295
1.821600 -0.007902 0.003914 0.003914 0.003814
1.822400 -0.008105 0.003240 0.003240 0.003248
1.823200 -0.008273 0.002608 0.002608 0.002609
1.824000 -0.008403 0.002031 0.002031 0.001911
1.824800 -0.008495 0.001525 0.001525 0.001169
1.825600 -0.008548 0.001104 0.001104 0.000396
1.826400 -0.008563 0.000782 0.000782 -0.000393
1.827200 -0.008542 0.000571 0.000571 -0.001185
1.828000 -0.008487 0.000480 0.000480 -0.001966
1.828800 -0.008409 0.000496 0.000496 -0.002089
1.829600 -0.008341 0.000506 0.000506 -0.001736
1.830400 -0.008287 0.000496 0.000496 -0.001425
1.831200 -0.008244 0.000468 0.000468 -0.001153
1.832000 -0.008211 0.000424 0.000424 -0.000918
1.832800 -0.008186 0.000365 0.000365 -0.000716
1.833600 -0.008167 0.000294 0.000294 -0.000545
1.834400 -0.008153 0.000215 0.000215 -0.000402
1.835200 -0.008143 0.000129 0.000129 -0.000285
1.836000 -0.008135 0.000039 0.000039 -0.000191
1.836800 -0.008129 -0.000051 -0.000051 -0.000118
1.837600 -0.008124 -0.000139 -0.000139 -0.000061
1.838400 -0.008120 -0.000222 -0.000222 -0.000020
1.839200 -0.008115 -0.000298 -0.000298 0.000008
1.840000 -0.008110 -0.000364 -0.000364 0.000026
1.840800 -0.008105 -0.000418 -0.000418 0.000036
1.841600 -0.008099 -0.000459 -0.000459 0.000039
1.842400 -0.008092 -0.000486 -0.000486 0.000038
1.843200 -0.008085 -0.000496 -0.000496 0.000033
1.844000 -0.008078 -0.000490 -0.000490 0.000027
1.844800 -0.008071 -0.000468 -0.000468 0.000021
1.845600 -0.008064 -0.000430 -0.000430 0.000014
1.846400 -0.008058 -0.000377 -0.000377 0.000009
1.847200 -0.008052 -0.000310 -0.000310 0.000005
1.848000 -0.008048 -0.000232 -0.000232 0.000002
1.848800 -0.008045 -0.000144 -0.000144 0.000000
1.849600 -0.008043 -0.000049 -0.000049 0.000000
1.850400 -0.008045 -0.000325 -0.000325 0.000400
1.851200 -0.008059 -0.000970 -0.000970 0.001101
1.852000 -0.008084 -0.001607 -0.001607 0.001674
1.852800 -0.008114 -0.002238 -0.002238 0.002122
1.853600 -0.008145 -0.002863 -0.002863 0.002445
1.854400 -0.008174 -0.003483 -0.003483 0.002650
1.855200 -0.008197 -0.004096 -0.004096 0.002738
1.856000 -0.008209 -0.004700 -0.004700 0.002715
1.856800 -0.008209 -0.005292 -0.005292 0.002587
1.857600 -0.008192 -0.005871 -0.005871 0.002357
1.858400 -0.008157 -0.006432 -0.006432 0.002032
1.859200 -0.008100 -0.006973 -0.006973 0.001617
1.860000 -0.008021 -0.007488 -0.007488 0.001120
1.860800 -0.007917 -0.007976 -0.007976 0.000545
1.861600 -0.007787 -0.008430 -0.008430 -0.000099
1.862400 -0.007631 -0.008848 -0.008848 -0.000808
1.863200 -0.007446 -0.009225 -0.009225 -0.001574
1.864000 -0.007234 -0.009558 -0.009558 -0.002390
1.864800 -0.006994 -0.009843 -0.009843 -0.003250
1.865600 -0.006727 -0.010076 -0.010076 -0.004147
1.866400 -0.006432 -0.010256 -0.010256 -0.005076
1.867200 -0.006110 -0.010379 -0.010379 -0.006029
1.868000 -0.005764 -0.010442 -0.010442 -0.007001
1.868800 -0.005393 -0.010445 -0.010445 -0.007986
1.869600 -0.004999 -0.010385 -0.010385 -0.008978
1.870400 -0.004583 -0.010262 -0.010262 -0.009972
1.871200 -0.004148 -0.010075 -0.010075 -0.010963
1.872000 -0.003696 -0.009824 -0.009824 -0.011945
1.872800 -0.003227 -0.009509 -0.009509 -0.012915
1.873600 -0.002745 -0.009132 -0.009132 -0.013868
1.874400 -0.002250 -0.008693 -0.008693 -0.014801
1.875200 -0.001746 -0.008194 -0.008194 -0.015710
1.876000 -0.001235 -0.007639 -0.007639 -0.016591
1.876800 -0.000718 -0.007028 -0.007028 -0.017442
1.877600 -0.000197 -0.006365 -0.006365 -0.018261
1.878400 0.000325 -0.005654 -0.005654 -0.019090
1.879200 0.000873 -0.004884 -0.004884 -0.022130
1.880000 0.001466 -0.004048 -0.004048 -0.024854
1.880800 0.002094 -0.003152 -0.003152 -0.027278
1.881600 0.002748 -0.002203 -0.002203 -0.029418
1.882400 0.003420 -0.001207 -0.001207 -0.031289
1.883200 0.004103 -0.000171 -0.000171 -0.032907
1.884000 0.004790 0.000899 0.000899 -0.034287
1.884800 0.005476 0.001997 0.001997 -0.035443
1.885600 0.006155 0.003117 0.003117 -0.036389
1.886400 0.006821 0.004253 0.004253 -0.037140
1.887200 0.007472 0.005399 0.005399 -0.037708
1.888000 0.008103 0.006551 0.006551 -0.038107
1.888800 0.008711 0.007703 0.007703 -0.038349
1.889600 0.009293 0.008851 0.008851 -0.038446
1.890400 0.009847 0.009990 0.009990 -0.038409
1.891200 0.010370 0.011116 0.011116 -0.038250
1.892000 0.010863 0.012225 0.012225 -0.037979
1.892800 0.011322 0.013313 0.013313 -0.037606
1.893600 0.011747 0.014378 0.014378 -0.037142
1.894400 0.012138 0.015416 0.015416 -0.036595
1.895200 0.012495 0.016424 0.016424 -0.035974
1.896000 0.012816 0.017401 0.017401 -0.035287
1.896800 0.013103 0.018344 0.018344 -0.034543
1.897600 0.013355 0.019251 0.019251 -0.033748
1.898400 0.013573 0.020121 0.020121 -0.032910
1.899200 0.013758 0.020951 0.020951 -0.032035
1.900000 0.013910 0.021742 0.021742 -0.031130
1.900800 0.014031 0.022492 0.022492 -0.030200
1.901600 0.014121 0.023201 0.023201 -0.029251
1.902400 0.014181 0.023867 0.023867 -0.028287
1.903200 0.014213 0.024492 0.024492 -0.027313
1.904000 0.014217 0.025074 0.025074 -0.026334
1.904800 0.014195 0.025613 0.025613 -0.025353
1.905600 0.014149 0.026111 0.026111 -0.024375
1.906400 0.014079 0.026566 0.026566 -0.023401
1.907200 0.013987 0.026981 0.026981 -0.022436
1.908000 0.013874 0.027354 0.027354 -0.021482
1.908800 0.013742 0.027687 0.027687 -0.020542
1.909600 0.013592 0.027981 0.027981 -0.019618
1.910400 0.013425 0.028237 0.028237 -0.018711
1.911200 0.013243 0.028455 0.028455 -0.017823
1.912000 0.013046 0.028637 0.028637 -0.016956
1.912800 0.012837 0.028783 0.028783 -0.016111
1.913600 0.012616 0.028894 0.028894 -0.015290
1.914400 0.012384 0.028972 0.028972 -0.014492
1.915200 0.012143 0.029019 0.029019 -0.013720
1.916000 0.011893 0.029034 0.029034 -0.012972
1.916800 0.011636 0.029019 0.029019 -0.012251
1.917600 0.011373 0.028977 0.028977 -0.011556
1.918400 0.011105 0.028906 0.028906 -0.010887
1.919200 0.010832 0.028810 0.028810 -0.010244
1.920000 0.010555 0.028689 0.028689 -0.009627
1.920800 0.010276 0.028544 0.028544 -0.009037
1.921600 0.009995 0.028376 0.028376 -0.008473
1.922400 0.009713 0.028188 0.028188 -0.007934
1.923200 0.009430 0.027979 0.027979 -0.007420
1.924000 0.009148 0.027751 0.027751 -0.006931
1.924800 0.008866 0.027505 0.027505 -0.006466
1.925600 0.008585 0.027242 0.027242 -0.006024
1.926400 0.008306 0.026964 0.026964 -0.005606
1.927200 0.008030 0.026671 0.026671 -0.005210
1.928000 0.007756 0.026363 0.026363 -0.004836
1.928800 0.007485 0.026043 0.026043 -0.004483
1.929600 0.007218 0.025711 0.025711 -0.004150
1.930400 0.006955 0.025368 0.025368 -0.003837
1.931200 0.006695 0.025015 0.025015 -0.003543
1.932000 0.006441 0.024652 0.024652 -0.003266
1.932800 0.006190 0.024281 0.024281 -0.003007
1.933600 0.005945 0.023902 0.023902 -0.002765
1.934400 0.005705 0.023516 0.023516 -0.002539
1.935200 0.005470 0.023123 0.023123 -0.002328
1.936000 0.005240 0.022725 0.022725 -0.002131
1.936800 0.005016 0.022321 0.022321 -0.001948
1.937600 0.004798 0.021913 0.021913 -0.001778
1.938400 0.004585 0.021501 0.021501 -0.001620
1.939200 0.004377 0.021085 0.021085 -0.001474
1.940000 0.004176 0.020667 0.020667 -0.001339
1.940800 0.003980 0.020246 0.020246 -0.001214
1.941600 0.003791 0.019823 0.019823 -0.001100
1.942400 0.003607 0.019399 0.019399 -0.000994
1.943200 0.003429 0.018974 0.018974 -0.000897
1.944000 0.003256 0.018548 0.018548 -0.000808
1.944800 0.003090 0.018122 0.018122 -0.000726
1.945600 0.002929 0.017695 0.017695 -0.000651
1.946400 0.002774 0.017270 0.017270 -0.000583
1.947200 0.002624 0.016845 0.016845 -0.000522
1.948000 0.002480 0.016421 0.016421 -0.000465
1.948800 0.002341 0.015998 0.015998 -0.000414
1.949600 0.002208 0.015577 0.015577 -0.000368
1.950400 0.002080 0.015158 0.015158 -0.000326
1.951200 0.001957 0.014742 0.014742 -0.000288
1.952000 0.001839 0.014327 0.014327 -0.000254
1.952800 0.001727 0.013916 0.013916 -0.000224
1.953600 0.001619 0.013507 0.013507 -0.000197
1.954400 0.001516 0.013101 0.013101 -0.000172
1.955200 0.001418 0.012699 0.012699 -0.000150
1.956000 0.001324 0.012300 0.012300 -0.000131
1.956800 0.001235 0.011905 0.011905 -0.000114
1.957600 0.001150 0.011514 0.011514 -0.000099
1.958400 0.001069 0.011127 0.011127 -0.000085
1.959200 0.000993 0.010744 0.010744 -0.000073
1.960000 0.000920 0.010366 0.010366 -0.000063
1.960800 0.000852 0.009992 0.009992 -0.000054
1.961600 0.000787 0.009623 0.009623 -0.000046
1.962400 0.000726 0.009259 0.009259 -0.000039
1.963200 0.000668 0.008901 0.008901 -0.000033
1.964000 0.000613 0.008547 0.008547 -0.000028
1.964800 0.000562 0.008199 0.008199 -0.000023
1.965600 0.000514 0.007856 0.007856 -0.000019
1.966400 0.000470 0.007519 0.007519 -0.000016
1.967200 0.000428 0.007188 0.007188 -0.000013
1.968000 0.000388 0.006862 0.006862 -0.000011
1.968800 0.000352 0.006543 0.006543 -0.000009
1.969600 0.000318 0.006230 0.006230 -0.000007
1.970400 0.000287 0.005924 0.005924 -0.000006
1.971200 0.000257 0.005623 0.005623 -0.000005
1.972000 0.000231 0.005330 0.005330 -0.000004
1.972800 0.000206 0.005043 0.005043 -0.000003
1.973600 0.000183 0.004763 0.004763 -0.000002
1.974400 0.000162 0.004490 0.004490 -0.000002
1.975200 0.000143 0.004224 0.004224 -0.000001
1.976000 0.000126 0.003966 0.003966 -0.000001
1.976800 0.000110 0.003714 0.003714 -0.000001
1.977600 0.000096 0.003470 0.003470 -0.000001
1.978400 0.000083 0.003234 0.003234 -0.000000
1.979200 0.000072 0.003005 0.003005 -0.000000
1.980000 0.000061 0.002784 0.002784 -0.000000
1.980800 0.000052 0.002571 0.002571 -0.000000
1.981600 0.000044 0.002365 0.002365 -0.000000
1.982400 0.000037 0.002168 0.002168 -0.000000
1.983200 0.000031 0.001979 0.001979 -0.000000
1.984000 0.000025 0.001798 0.001798 -0.000000
1.984800 0.000021 0.001625 0.001625 -0.000000
1.985600 0.000017 0.001461 0.001461 -0.000000
1.986400 0.000013 0.001305 0.001305 -0.000000
1.987200 0.000010 0.001157 0.001157 -0.000000
1.988000 0.000008 0.001018 0.001018 -0.000000
1.988800 0.000006 0.000888 0.000888 -0.000000
1.989600 0.000005 0.000767 0.000767 -0.000000
1.990400 0.000003 0.000654 0.000654 -0.000000
1.991200 0.000002 0.000550 0.000550 -0.000000
1.992000 0.000002 0.000455 0.000455 -0.000000
1.992800 0.000001 0.000369 0.000369 -0.000000
1.993600 0.000001 0.000292 0.000292 -0.000000
1.994400 0.000000 0.000223 0.000223 -0.000000
1.995200 0.000000 0.000164 0.000164 -0.000000
1.996000 0.000000 0.000114 0.000114 -0.000000
1.996800 0.000000 0.000073 0.000073 -0.000000
1.997600 0.000000 0.000041 0.000041 -0.000000
1.998400 0.000000 0.000018 0.000018 -0.000000
1.999200 0.000000 0.000005 0.000005 -0.000000
2.000000 0.000000 0.000000 0.000000 -0.000000
