quri on lammps
hi sir,
I am Nandlal pingua from IIT kanpur, INDIA new user of LAMMPS.
Question :-
  1. I have a doubts that is what formate should i used for time-step. e.g-either 2*10e-8 or 0.00000002. in both case simulation work results are different so, what formate i will use in time steps? one more thing that, is there important role of time-step in simulation? I have seen if i increase or decrease the time-step in that case one error shown after first iteration all atoms lost. what is reason behind i am not getting.?
  2. In lattice-command, How i will known that which style i will choose for simulation? e.g fcc or bcc or hcp or sc etc
  3. How neighbour list effect the simulation? is it is high or low build
Thank You
Nandlal
hi sir,
Question :-
1) I have a doubts that is what formate should i used for time-step.
See the literature/previous questions in mailing lists.
2) In lattice-command, How i will known that which style i will choose for
Then why are u doing LAMMPS??
3) How neighbour list effect the simulation? is it is high or low build
See the manual
Sagar
http://books.google.co.in/books?id=O32VXB9e5P4C&printsec=frontcover&source=gbs_ge_summary_r&cad=0#v=onepage&q&f=false
hope it helps …
Rajom
“quri”…:slight_smile:
hi sir,
Question :-
the valid format for floating point numbers is documented in any C/C++
manual. look for the atof() or strtod() function calls.
this is not a LAMMPS but an MD question. please consult a text book or
ask your adviser.
if you don't know, don't use it. it is not required at all.
the answer to the first part is - again - explained in text books on
MD and in the LAMMPS paper referenced in the manual.
i don't understand the second part of the question.
