Maybe I understood. It's because in the TIP3P one puts:
pair_coeff * 2 0.0000 0.0000
so no-one interacts with hydrogens?
Aris
----Messaggio originale----
Da: [email protected]...
Data: 06/05/2014 13.58
A: <[email protected]>
Cc: "Lammps-users"<[email protected]>
Ogg: R: Re: [lammps-users] Per atom energy of rigid waterOk thanks, but it should remain the contribution of pair potentials or not?
Here is my setting:
# SPC/E water box benchmarkunits real
atom_style fullread_data system_chosen
pair_style lj/cut 6.0
pair_coeff 1 1 0.1521 3.1507
pair_coeff * 2 0.0000 0.0000bond_style harmonic
angle_style harmonic
dihedral_style none
improper_style nonebond_coeff 1 450 0.9572
angle_coeff 1 55 104.52special_bonds lj 0.0 0.0 0.5
neighbor 2.0 bin
neigh_modify every 1 delay 10 check yesfix NVT all nvt temp 300.0 300.0 100.0
velocity all create 300 432567 dist uniform
fix 1 all shake 0.0001 20 0 b 1 a 1
timestep 2.0
thermo 10
run 100000
unfix NVT
fix NVE all nve
reset_timestep 0
velocity all zero linear
compute myKE all ke/atom
compute myPE all pe/atom
thermo 1dump mydump all custom 1 energy.file c_myPE c_myKE
run 500000
-----------------------and the file system_chosen begins like this:
LAMMPS Description
192 atoms
128 bonds
64 angles
0 dihedrals
0 impropers2 atom types
1 bond types
1 angle types0.0 12.448 xlo xhi
0.0 12.448 ylo yhi
0.0 12.448 zlo zhiMasses
1 15.9994
2 1.008Atoms
1 1 1 -0.834 0.0 0.0 0.0
2 1 2 0.417 0.577345898614 0.577345898614 0.577359
3 1 2 0.417 -0.577345898614 -0.577345898614 0.577359
4 2 1 -0.834 0.0 0.0 3.112
5 2 2 0.417 0.577345898614 0.577345898614 3.689359------------------------------------------------------------
DId I do something wrong?
Data: 06/05/2014 12.28
A: "[email protected]..."<[email protected]...>
Ogg: Re: [lammps-users] Per atom energy of rigid waterHello,
I tried to print per atom energy using TIP3P parameters of the
documentation per both flexible and rigid water. I used acompute myPE all pe/atom
In the case of rigid water several atoms seem to have zero potential
energy
