radiation damage in material
Dear Sir
I am a new user of LAMMPS. I am trying to simulate for primary radiation damage. Below I have my input script. I am getting the below error
set group PKA vx 109.5108
ERROR: Illegal set command (…/set.cpp:517)
Can anyone help me with it?
here is my input script
Displacement Cascade in Fe
-------------- Initialize Simulation ------------
echo both
atom_style atomic
neighbor 1.0 bin
--------------- Creat Atoms / Geometry -----------------------
lattice bcc 2.8665 # bcc lattice spacing 2.8665 Angstrom
region box block 0 25 0 25 0 25
create_box 1 box
create_atoms 1 box basis 1 1 basis 2 1
mass 1 55.847
region rPKA sphere 12.5 12.4 24.5 .1
sphere defined at the top/center of domain, initiate pka down
Note atomic radius Fe = 1.26 A, Nearest Neighbor 1.24 A
masses not necessary ?? for EAM potentials - contained in potential file
------------------Define Interatomic Potential -----------------
pair_style eam/fs
pair_coeff * * Fe_2.eam.fs Fe
Groups
region rallatoms block INF INF INF INF INF INF
region rinterior block 2 23 2 23 2 INF
region rexterior block 2 23 2 23 2 INF side out
group interior region rinterior
group exterior region rexterior
group PKA region rPKA
--------------Initialization----------------
compute 1 all temp
compute 2 interior coord/atom cutoff 2.2
compute 3 interior ke/atom
velocity all create 1200.0 34986
fix 1 all nve # specifiy constant NVE interation to update position andn velocity for atoms in ther group each timestep
fix 2 exterior temp/rescale 1 100.0 100.0 0.5 1.0 region rexterior
fix 3 interior temp/rescale 1 100.0 100.0 0.5 1.0 region rinterior
timestep 0.001
thermo 100
thermo_style custom step temp pe etotal press
run 1000
unfix 3
run 1000
set PKA velocities to correspond to ~ 10keV - 2620.549 Ang/ps
set group PKA vy 301.1547
set group PKA vz -2600.8815
set timestep to smaller value for initial phase of collision (.01 fs for .2 ps)
timestep 0.00001
thermo 100
dump 1 interior coustom 100 test_init_col.dump x y z c_3 tag type c_2
dump 2 PKA coustom 100 PKA_traj_init_col.dump x y z c_3 tag type c_2
run 20000
run intermediate phase with intermediate timestep (.1 fs for 1 ps)
timestep 0.0001
undump 1
undump 2
dump 3 interior coustom 100 test_inter_evolve.dump x y z c_3 tag type c_2
dump 4 PKA coustom 100 PKA_traj_inter_evolve.dump x y z c_3 tag type c_2
run 10000 # run the collisional phase for .1 ps
timestep 0.0001
undump 3
undump 4
timestep 0.001
dump 5 interior coustom 100 test_final_evolve.dump x y z c_3 tag type c_2
dump 6 PKA coustom 100 PKA_traj_final_evolve.dump x y z c_3 tag type c_2
Thank you
Mohammad khan
There is no need to repost the exact same inquiry to the mailing list within an hour. Please keep in mind, that people who are responding may live in (very) different time zones and are volunteering their time to respond. As a rule of the thumb, you should wait at least two business days before reposting.
Thanks for your understanding,
Axel.
