Dear All, how can I set the random seed for the nvt fix only?
thanks
David
you don't, since fix nvt doesn't use any random numbers.
I see, I was a bit confused by these:
velocity gr create 1000.0 24564 dist gaussian
fix 1 gr nvt temp 300.0 300.0 100.0
so what is happening here?
thanks
David
fix 1 gr nvt temp 300.0 300.0 100.0so what is happening here?
those are two different commands.
the first creates and assigns an initial velocity distribution,
the seconds adds the nvt fix to the list of fixes to be
executed during the run.
