randomize propagation direction of an elliptical rigid body
I am simulating an elliptical shape rigid body particles in a sinusoidal cavity in 2D. It interacts with the background dpd solvent. In addition to that I want to add a force on the rigid body particle in each step which will randomize it’s propagation direction. The force should be like:
Fx = F0 cos(theta)
Fy = F0 sin(theta)
dtheta/dt = random,
theta is the angle between the propagation direction and channel axis (x axis say) and it varies randomly.
Please suggest me if there is any way to do that with existing lamps codes.
Thanks in advance
Regards,
CMB
will randomize it's propagation direction. The force should be like:
Fx = F0 cos(theta)
Fy = F0 sin(theta)
dtheta/dt = random,
what is the point of this?
your dpd thermostat will already add randomization to the constituent
particles of your rigid bodies, which will include residual random
rotation forces.
i don't know any way to do this explicitly without writing some C++
code. please note that some of the rigid fixes offer an internal
langevin thermostat that operates directly on the rigid bodies.
No,
However, you can modify the fix addforce for what you want.
Wade
------------------ Original ------------------
Fix addforce can add a force to one (or more) particles which is
an equal- or atom-style variable. Those variables can use a random()
function (see the variable doc page) which will be a different random #
each time the variable is invoked.
Axel you are right. Theta is already random because of the dynamics with solvent. So, if I just calculate theta in each step and add the forces: F0 cos(theta), F0 sin(theta), to each particle in the rigid body, it will give the rigid body an additional kick along the propagation direction.
Now the question is how to calculate theta in each step.
For rigid bodies I think LAMMPS does not calculate it directly. So, if I find out two particles, one at the head (2) and the other at the tail (1) and the line joining them passing through the centre of mass of the rigid body, I can define a variable like
theta = atan[(y2-y1)/(x2-x1)]
This will give me the propagation direction.
Once theta is calculated, I will be able to add the forces.
Please suggest me if I am thinking it right.
Thanks and regards,
CMB
Fx = F0 cos(theta)
Fy = F0 sin(theta)
dtheta/dt = random,
rotation forces.
i don’t know any way to do this explicitly without writing some C++
No, you didn’t get what I was trying to explain.
