Dear Lammps users,
I could not find a formula for calculating RDF in Lammps. Would like to know if it is the same as the bellow formula
N: total number of ion pairs
n: number of density
rij: distance between atoms i and j
I asked because I am simulating a paper, they used the above formula for calculating their RDF. I also calculated RDF for the crystal by Lammps, the peak positions are exactly the same as the paper but their intensity is very different even their relative heights. Would like to know if I need to do some normalization?
I appreciate your reply.
Regards,
Sara
Dear Lammps users,
yes, it pretty much is. there only is an additional correct for finite
size effect, so that g(r) for r -> r_c becomes exactly 1.0 in a dense,
homogeneous, and liquid mono-atomic system.
no, but the exact results also depend on the details of what kind of pairs
are considered. this is particularly crucial for any system with bonds.
Hi Axel,
Thanks for your reply.
I considered the pairs of atoms exactly the same as the paper. Would you please see the attached file. I appreciate if you have more comments for me.
Kind regards,
Sara
Comparing RDFs.docx (170 KB)
Hi Axel,
me.
not really. i suggest you first use compute rdf with a simpler system to
confirm that you are using it correctly.
it has been benchmarked against multiple different RDF implementations and
come out to work correctly in all cases. this includes the RDF code
implementations in VMD on GPU and CPU, the latter of which i wrote myself
based on a code i wrote and extensively tested during my own PhD studies
almost 20 years ago. the code in VMD has seen some close scrutiny from a
lot of people and over the years.
Hi all,
The system you are studying is solid, so results should be dependent on size of bin, i.e. delta_r is used to numerically compute g®. So, I think that first you should test with different number of bins!
That’s a good point, about the number of bins. Hopefully the authors specified the number of bins they used (wistful thinking probably).
